on 14-01-2022 14:00
Me again with another post, sorry!
So after having an issue with the speed to the hub not being 1gb this has been sorted after a couple of engineers came out, so thanks for all the help
I am logging in the hub via web browser and when I look at connected devices there are a few devices called unknown and also the laptop I am on does not appear?
Also when I change a device to a laptop/mobile/desk top etc it does not save it and also does not save the name if I change it from unknown
If I was to reset the hub would my 3 boxes all connect automatically? I could then connect each device to see what they are called?
Answered! Go to Answer
on 25-01-2022 09:10
So this is my data if that helps? Still really slow speeds!!!
25 | 331000000 | 5.699997 | 40.366287 | QAM256 | 25 |
1 | 139000000 | 7.800003 | 40.946209 | QAM256 | 1 |
2 | 147000000 | 7.599998 | 40.366287 | QAM256 | 2 |
3 | 155000000 | 7.699997 | 40.366287 | QAM256 | 3 |
4 | 163000000 | 7.400002 | 40.366287 | QAM256 | 4 |
5 | 171000000 | 7.300003 | 40.366287 | QAM256 | 5 |
6 | 179000000 | 7.199997 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 7.300003 | 40.366287 | QAM256 | 7 |
8 | 195000000 | 6.900002 | 40.366287 | QAM256 | 8 |
9 | 203000000 | 7.099998 | 40.366287 | QAM256 | 9 |
10 | 211000000 | 6.900002 | 40.366287 | QAM256 | 10 |
11 | 219000000 | 7.199997 | 40.366287 | QAM256 | 11 |
12 | 227000000 | 7.099998 | 40.946209 | QAM256 | 12 |
13 | 235000000 | 7.400002 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 7.199997 | 40.366287 | QAM256 | 14 |
15 | 251000000 | 7.300003 | 40.946209 | QAM256 | 15 |
16 | 259000000 | 7.000000 | 40.946209 | QAM256 | 16 |
17 | 267000000 | 7.199997 | 40.366287 | QAM256 | 17 |
18 | 275000000 | 7.000000 | 40.366287 | QAM256 | 18 |
19 | 283000000 | 6.699997 | 40.946209 | QAM256 | 19 |
20 | 291000000 | 6.300003 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 6.199997 | 40.366287 | QAM256 | 21 |
22 | 307000000 | 6.699997 | 40.366287 | QAM256 | 22 |
23 | 315000000 | 6.599998 | 40.366287 | QAM256 | 23 |
24 | 323000000 | 6.099998 | 38.983261 | QAM256 | 24 |
26 | 339000000 | 6.199997 | 40.366287 | QAM256 | 26 |
27 | 347000000 | 6.000000 | 40.946209 | QAM256 | 27 |
28 | 355000000 | 5.800003 | 38.983261 | QAM256 | 28 |
29 | 363000000 | 6.000000 | 38.983261 | QAM256 | 29 |
30 | 371000000 | 6.400002 | 40.366287 | QAM256 | 30 |
31 | 379000000 | 5.699997 | 40.366287 | QAM256 | 31 |
25 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.946209 | 0 | 0 |
2 | Locked | 40.366287 | 8 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 40.366287 | 29 | 0 |
9 | Locked | 40.366287 | 6 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.946209 | 0 | 0 |
13 | Locked | 40.366287 | 7 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 40.946209 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.946209 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 7 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.946209 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 41 | 6.2 | 621658 | 22 |
on 25-01-2022 09:11
1 | 53700000 | 29.020599 | 5120 KSym/sec | 64QAM | 10 |
2 | 39400000 | 29.020599 | 5120 KSym/sec | 64QAM | 12 |
3 | 46200000 | 29.020599 | 5120 KSym/sec | 64QAM | 11 |
4 | 60300000 | 29.020599 | 5120 KSym/sec | 64QAM | 9 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 25-01-2022 09:37
on 25-01-2022 09:49
Got no idea? I log onto the hub to show connected devices and my phone, laptop or desktop computer are on there, totally pointless having it!
on 25-01-2022 09:59
what is your connection - FTTP or coax from the cabinet - the upstream levels are too low for coax - not sure on FTTP - imo they need looking at either way
how that will affect wifi speeds i have no idea but they are not right
on 25-01-2022 10:02
Thanks for the reply, got no idea about my connection!! do you think Virgin will look at this?
on 25-01-2022 10:32
@gingermoonman wrote:Thanks for the reply, got no idea about my connection!! do you think Virgin will look at this?
yes they will - will flag the thread and get them back
on 25-01-2022 10:43
sorry are you going to arrange them to come back or do I need to do it?
Thanks for the help
on 25-01-2022 11:01
@gingermoonman wrote:sorry are you going to arrange them to come back or do I need to do it?
Thanks for the help
you can ring and tell them the upstream is too low - if you get offshore no idea what they will do - their solutions are many and varied - non will do any thing
or you can wait for VM to get back to the thread they will look at things and decide if it need a tech visit
on 25-01-2022 11:04
Thats great will wait for VM, does it normally take long for them to come back?
