on 07-01-2021 11:58
I currently have my Hub 4 connected to an Orbi Mesh Wifi Hub (with Orbi as a router not as an AP and the Hub 4 as a modem).
Wifi speed on the 5G wifi from the Virgin hub is c.200mbps (even beside the router) but the speed from the Orbi is only 60-70 (despite it being connected by ethernet cable to the Virgin router that is getting 500-600 mbps).
Turning the Virgin Hub into a modem made no difference.
Any ideas highly appreciated - I have had two Virgin engineers out now and a new Virgin Hub but they do not understand why even the wifi speed from the hub is so low (given only 2 competing wifi routers and we are on an uncongested channels and speedtesting directly beside it)
Cheers
Phil
on 07-01-2021 12:17
on 07-01-2021 12:29
on 07-01-2021 12:35
Also make sure your Ethernet cable is Cat 5e or above.
on 07-01-2021 12:49
Hi found it
100M Full on LAN 1 (where it is connected)
the speed is still 60-70 with no wireless signal from the Hub
Cheers
07-01-2021 12:51 - edited 07-01-2021 12:52
If it's 100mb on the Ethernet on the Orbi then 60mb-70mb would be about right
on 07-01-2021 13:03
Sorry missed a 0 it is 1000m/full so it should be taking the full 600mbps coming down the pipe to the hub
on 07-01-2021 13:05
on 07-01-2021 13:14
Hi it is a cat 6 cable and I did try another cat 6 cable just in case and got the same result
on 07-01-2021 13:23
What speed do you get wired to the Orbi?
