on 06-02-2022 14:54
Problem started a week ago, Internet drops out 3-4 minutes every hour.
Anyone see anything obvious:
Item Status Comments
Acquired Downstream Channel(Hz) 306000000 Locked
Ranged Upstream Channel(Hz) 60300000 Ranged
Provisioning State Online Operational
1 306000000 7.4 40 QAM 256 22
2 138000000 5 36 QAM 256 1
3 146000000 5.5 38 QAM 256 2
4 154000000 4.6 37 QAM 256 3
5 162000000 5.1 38 QAM 256 4
6 170000000 4.7 38 QAM 256 5
7 178000000 5.6 38 QAM 256 6
8 186000000 5.7 39 QAM 256 7
9 194000000 6.4 39 QAM 256 8
10 202000000 5.6 39 QAM 256 9
11 210000000 5.7 39 QAM 256 10
12 218000000 5.6 34 QAM 256 11
13 226000000 6.1 38 QAM 256 12
14 234000000 6 39 QAM 256 13
15 242000000 6.3 39 QAM 256 14
16 250000000 6.7 40 QAM 256 15
17 258000000 7 40 QAM 256 16
18 266000000 6.9 40 QAM 256 17
19 274000000 6.8 40 QAM 256 18
20 282000000 6.7 40 QAM 256 19
21 290000000 7.1 40 QAM 256 20
22 298000000 7.5 40 QAM 256 21
23 314000000 7.7 40 QAM 256 23
24 322000000 7.6 40 QAM 256 24
25 330000000 7.8 40 QAM 256 25
26 338000000 7.8 39 QAM 256 26
27 346000000 7.5 40 QAM 256 27
28 354000000 7.2 40 QAM 256 28
29 362000000 7.7 40 QAM 256 29
30 370000000 7.5 40 QAM 256 30
31 378000000 7.7 40 QAM 256 31
1 Locked 40 0 5
2 Locked 36 77514 7095654
3 Locked 38 1 763208
4 Locked 37 0 18387
5 Locked 38 0 52
6 Locked 38 0 67
7 Locked 38 0 247
8 Locked 39 0 22
9 Locked 39 0 5
10 Locked 39 0 9
11 Locked 39 0 6
12 Locked 34 0 177160
13 Locked 38 0 3
14 Locked 39 0 3
15 Locked 39 0 4
16 Locked 40 0 3
17 Locked 40 0 1
18 Locked 40 0 4
19 Locked 40 0 4
20 Locked 40 0 5
21 Locked 40 0 5
22 Locked 40 0 5
23 Locked 40 0 7
24 Locked 40 0 4
25 Locked 40 0 5
26 Locked 39 0 4
27 Locked 40 0 2
28 Locked 40 0 2
29 Locked 40 0 2
30 Locked 40 0 1
31 Locked 40 0 0
1 60300000 50.5 5120 QAM 64 1
2 53700000 51.3 5120 QAM 64 2
3 46200000 51.5 5120 QAM 64 3
4 39400000 51.5 5120 QAM 64 4
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access Allowed
Maximum Number of CPEs 3
Baseline Privacy Enabled
DOCSIS Mode 3.1
Config file cmreg-vmdg660-bbt053+voc-b.cm
SFID 302808
Max Traffic Rate 575000000 bps
Max Traffic Burst 42600 bytes
Min Traffic Rate 0 bps
SFID 302810
Max Traffic Rate 128000 bps
Max Traffic Burst 3044 bytes
Primary Upstream Service Flow
SFID 302807
Max Traffic Rate 38520000 bps
Max Concatenated Burst 16320 bytes
Scheduling Type Best Effort
SFID 302809
Max Concatenated Burst 1522 bytes
Network Log (I overwrrote XXXX MAC addresses)
06-02-2022 14:24:37 notice CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=XXX;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:24:17 notice REGISTRATION COMPLETE - Waiting for Operational status
06-02-2022 14:24:11 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=XXXX;CMTS-MAC=XXXX;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:24:10 notice TLV-11 - unrecognized OID;CM-MAC=XXXXCMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:24:07 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=XXXXX;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:24:05 notice Honoring MDD; IP provisioning mode = IPv4
06-02-2022 14:24:05 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXXX;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:24:04 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXXXX;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:24:00 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXXXX;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:24:00 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXXXX:05;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:23:59 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXXXX;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-02-2022 14:22:19 critical Cable Modem Reboot from SNMP
06-02-2022 13:40:53 critical Cable Modem Reboot from SNMP
06-02-2022 11:48:39 critical Cable Modem Reboot from SNMP
06-02-2022 10:07:47 critical Cable Modem Reboot from SNMP
06-02-2022 08:24:34 critical Cable Modem Reboot from SNMP
06-02-2022 07:34:26 critical Cable Modem Reboot from SNMP
06-02-2022 05:56:06 critical Cable Modem Reboot from SNMP
06-02-2022 05:36:46 critical Cable Modem Reboot from SNMP
06-02-2022 03:22:39 critical Cable Modem Reboot from SNMP
06-02-2022 02:07:33 critical Cable Modem Reboot from SNMP
05-02-2022 23:34:13 critical Cable Modem Reboot from SNMP
05-02-2022 22:47:06 critical Cable Modem Reboot from SNMP
05-02-2022 21:44:03 critical Cable Modem Reboot from SNMP
Answered! Go to Answer
on 06-02-2022 15:05
There’s noise on the downstream line and your upstream levels are too high.
Unless there’s an area issue you’ll need an engineer.
on 06-02-2022 15:05
on 09-02-2022 08:53
Hi @DarkerFirestar,
Welcome to our Community Forums! Thank you for your first post, and I'm sorry to hear that you're having some ongoing issues with your broadband connection! I can understand how frustrating this can be.
I was able to run some further checks on our systems, and I can see that there are some ongoing issues with your upstream and downstream power levels, which can impact your connection.
Unfortunately, we're unable to resolve this issue remotely, so I will have to arrange for a technician appointment. I will send you a Private Message to confirm a few details. Please keep an eye out for a purple envelope at the top right corner of your Forum page. I will be in touch soon.
Thank you.
on 09-02-2022 09:02
That's much appreciated Pauline, Good news is that the Engineer has been out, he was very good, tracked all cables and tested, I am also very close to the street box. However, he was going to replace the pavement to house cable and we found that a hedge had grown through the conduit trapping it in place, so he put in a call to get the cable team out to replace that for me, so hopefully once that's done all will be well. Thanks again for the responses here and great to be part of the community.
on 11-02-2022 10:11
Do keep us updated with how things get on DarkerFirestar.
Kind regards,
Zak_M
