on 16-04-2021 19:53
Hi All,
I would really appreciate some support here, I have been pulling my hair out the last two days with not being able to get this to work. I purchased Asus RT-AC86U as I am having issues when gaming, mainly high buffer bloating which is causing packet burst in game and making it lag and stutter.
After doing a lot of reading I decided to go with this, no matter what I do I just can't get it to connect to the internet, I have done the following:
All I get on the Asus back end software ''ISP's DHCP did not function Properly''.
I know the router is not faulty as yesterday I purchased the Netgear Nighthawk and I had the same issue with that, after spending nearly 2 hours on the phone with Netgear I returned the item assuming it might just be faulty.
Any help in getting this sorted would be amazing. Thanks in advance.
Answered! Go to Answer
on 16-04-2021 22:19
No
I have turned on modem mode but I am still able to pick up my hub 4 WiFi signal even though I can’t connect to the internet. I have then connected the ASUS router to the 4th Ethernet port although I have tried the first.
below are my wan settings.
on 16-04-2021 22:23
on 16-04-2021 22:24
@Daani350 wrote:No
Thats not right, with the hub in modem mode the WiFi is turned off. Could be you have a faulty hub.
on 16-04-2021 22:26
Do I maybe need to try to put it into modem mode wired? Even though when I log into the hub setting it shows it as modem mode
on 16-04-2021 22:26
@Daani350 wrote:
image attached
Your Asus settings look ok, i suspect the hub has an issue.
on 16-04-2021 22:27
@Daani350 wrote:Do I maybe need to try to put it into modem mode wired? Even though when I log into the hub setting it shows it as modem mode
Worth a try.
on 16-04-2021 22:32
Will give this a go in the morning. I have tried to hard reset my hub a number times and put it in modem mode even though it shows it’s in modem mode I can pick up the network WiFi in my search
on 17-04-2021 20:48
As already stated the hub shouldn’t be broadcasting Wifi in modem mode.
I had to do several pinhole resets on mine to get it to function “correctly”.
