06-08-2022 17:48 - edited 06-08-2022 17:49
Hello everyone hope you’re well,
For the past week or so, I’ve noticed some issues with my Hub 4 Connection.
I’ve seen it reboot twice within the space of a week, once at around exactly 00:00 and this morning at around 3AM. As I also work night shifts at home, this affects my ability to work and this is happening whilst the hub is in Modem Mode (I use my own UDM Pro Router and another access point connected to it).
I have also set up a BQM Graph and there are some random ping spikes. Can someone from VM please check my Hub to see if it is in spec first of all?
The BQM Graph is below and I’ll copy the hub config for you.
on 06-08-2022 17:52
3.0 Downstream channels
25 | 331000000 | 3.1 | 39 | QAM256 | 25 |
1 | 139000000 | 4.2 | 39 | QAM256 | 1 |
2 | 147000000 | 3.9 | 40.4 | QAM256 | 2 |
3 | 155000000 | 4 | 40.4 | QAM256 | 3 |
4 | 163000000 | 4.1 | 40.4 | QAM256 | 4 |
5 | 171000000 | 4 | 39 | QAM256 | 5 |
6 | 179000000 | 4.3 | 40.4 | QAM256 | 6 |
7 | 187000000 | 4.3 | 39 | QAM256 | 7 |
8 | 195000000 | 4.4 | 39 | QAM256 | 8 |
9 | 203000000 | 4.6 | 39 | QAM256 | 9 |
10 | 211000000 | 4.6 | 40.4 | QAM256 | 10 |
11 | 219000000 | 4.5 | 40.4 | QAM256 | 11 |
12 | 227000000 | 4.6 | 40.4 | QAM256 | 12 |
13 | 235000000 | 4.4 | 40.4 | QAM256 | 13 |
14 | 243000000 | 4.3 | 40.4 | QAM256 | 14 |
15 | 251000000 | 4.3 | 39 | QAM256 | 15 |
16 | 259000000 | 3.8 | 39 | QAM256 | 16 |
17 | 267000000 | 3.4 | 39 | QAM256 | 17 |
18 | 275000000 | 3.1 | 39 | QAM256 | 18 |
19 | 283000000 | 2.9 | 38.6 | QAM256 | 19 |
20 | 291000000 | 3 | 38.6 | QAM256 | 20 |
21 | 299000000 | 4 | 38.6 | QAM256 | 21 |
22 | 307000000 | 3.4 | 39 | QAM256 | 22 |
23 | 315000000 | 2.9 | 38.6 | QAM256 | 23 |
24 | 323000000 | 2.8 | 39 | QAM256 | 24 |
26 | 339000000 | 3.1 | 39 | QAM256 | 26 |
27 | 347000000 | 3.4 | 39 | QAM256 | 27 |
28 | 355000000 | 3.7 | 38.6 | QAM256 | 28 |
29 | 363000000 | 3.5 | 39 | QAM256 | 29 |
30 | 371000000 | 3.7 | 38.6 | QAM256 | 30 |
31 | 379000000 | 3.7 | 39 | QAM256 | 31 |
25 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.605377 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.605377 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM2048 | 759 |
159 | Locked | 40 | 4.4 | 59541822 | 3 |
on 06-08-2022 17:53
1 | 60300000 | 32 | 5120 KSym/sec | 64QAM | 1 |
2 | 39400000 | 32 | 5120 KSym/sec | 64QAM | 4 |
3 | 46200000 | 31.5 | 5120 KSym/sec | 64QAM | 3 |
4 | 53700000 | 32 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 06-08-2022 17:53
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | ;kfoA,.iyewrkldJKDHSUBsgvca69 |
SFID | 28217 |
Max Traffic Rate | 1200000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 28354 |
Max Traffic Rate | 55000270 |
Max Concatenated Burst | 16320 |
Scheduling Type | bestEffort |
on 06-08-2022 17:54
Wed 20/07/2022 18:48:27 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 20/07/2022 19:00:43 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 20/07/2022 19:08:10 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 20/07/2022 22:54:12 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 21/07/2022 00:50:52 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 23/07/2022 04:58:42 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 23/07/2022 07:48:20 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 24/07/2022 10:14:56 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 24/07/2022 10:14:57 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 24/07/2022 13:48:55 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 27/07/2022 22:14:57 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 27/07/2022 22:14:57 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 28/07/2022 19:34:48 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 29/07/2022 15:55:49 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 30/07/2022 23:47:55 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 31/07/2022 00:07:09 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 31/07/2022 00:19:24 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 31/07/2022 01:32:39 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 01/08/2022 23:10:58 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 01/08/2022 23:10:58 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 02/08/2022 11:47:29 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 03/08/2022 12:11:28 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 03/08/2022 15:12:51 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 04/08/2022 17:13:01 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 04/08/2022 17:13:01 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 04/08/2022 20:07:58 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 05/08/2022 22:04:55 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 06/08/2022 03:37:35 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 06/08/2022 03:49:50 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 06-08-2022 18:34
Upstream on the low side, but I expect it’s just VM doing some quick overnight work. Do you know if your WAN address has changed?
on 06-08-2022 18:36
Hey Tudor,
It definitely has at some point but I have no idea when - I had a previous Graph set up (since deleted as it was disabled) but I think that was a few months ago now. I had a different WAN IP for it than what I have now.
on 09-08-2022 09:49
Hey Raident10, thank you for reaching out and I am sorry to hear you are having some connection issues.
I have taken a look from our side and I cannot see no issues everything is running the way it should be.
How was the connection over the weekend, any improvement at all?
Please do let me know. Thanks
Matt - Forum Team
New around here?
on 09-08-2022 23:52
Hey Matt I hope you’re well,
Mainly things seem fine, however looking at that graph I linked, I’m still getting ping spikes on the WAN Interface and it looks like a little bit of packet loss as well.
It seems every so often it shoots up.
Take care,
on 12-08-2022 08:40
Hi there @Raident10
Thank you so much for popping back to us.
I have checked diagnostics again and there do not seem to be any issues at all with the Hub specs, and everything is performing as we would expect.
How have things been looking since your last message? Have you noticed any issues at all when using devices connected?
Thanks again.
