on 13-12-2020 11:01
on 13-12-2020 11:05
Four.
All four useable in Router Mode.
One useable in Modem Mode.
on 13-12-2020 11:07
Hello
The hub 4 has 4 Ethernet sockets.
Regards Mike
on 13-12-2020 11:21
on 13-12-2020 11:30
Just get an unmanaged gigabit >> switch << the metal case ones are better for heat dissipation.
on 13-12-2020 11:05
Four.
on 13-12-2020 11:07
Hello
Regards Mike
on 13-12-2020 11:21
on 13-12-2020 11:25
on 13-12-2020 11:30
on 13-12-2020 11:32
on 13-12-2020 11:35
on 13-12-2020 11:37
Hello
Your welcome, if you have any more queries by all means come on back to the forum we do have a great team of VM staff members, VIPs and normal customers with a great deal of knowledge. Stay safe and have a great weekend.
Regards Mike
on 13-12-2020 11:38
With a switch similar to the one in the link you use one port on the Hub to connect to the switch giving seven free ports on the switch.
This will give 10 ports available used in whatever permutation that you want.
