on 19-05-2022 20:56
Hello all,
I know this is probably a dumb question, but I just want to be sure. I recently upgraded to the Hub 4 as I changed to Gigabit broadband. I know with the Hub 3, some of the ethernet ports were limited in the speed that they could offer. Just wanting to check if there are any specific ports I should use on the Hub 4 to ensure I am getting the best speeds possible?
Answered! Go to Answer
on 19-05-2022 21:06
All Ethernet ports are the same on both Hub3s and Hub4s. The hub4 ports have a maximum of 940M.
on 19-05-2022 21:06
on 19-05-2022 21:06
