jameshartley
Hub 4 Eligibility
Is it possible to request an upgrade to a Hub 4 from a SuperHub 3? Or does it remain the case that only those in Gig1 areas are eligible?
My SuperHub 3 has started to randomly reboot recently, which has caused great inconvenience whilst trying to work. I can be certain that it is the whole device rebooting rather than just the fibre dropping, because I can see the system uptime reset to 0 in the web interface.
Instead of replacing the router & WiFi functionality with my own hardware and running the SuperHub 3 in modem mode, I wanted to check if there was the option of upgrading to the Hub 4.
Tags (1)
tehwolf
  • 1.58K
  • 256
  • 383
Superfast
Re: Hub 4 Eligibility
Pretty sure it's just gig1 areas that are eligible for the 4, and even then, only if you're in a heavily contended area.. if your hub is faulty, it will likely be replaced with another 3.
HowardML
  • 11.86K
  • 1.38K
  • 5.56K
This is the position. The Hub 4 is primarily intended and available immediately for anyone who takes up the Gig1 offer from VM - where their area is has Gig1 available. That is how I got mine. The Hub 3 does not support Gig1 speeds.
In some other areas where there are known issues of congestion a Hub 4 may be offered to see if that helps. That is because the Hub 4 can take advantage of more downstream channels than the Hub 3.
If your Hub 3 is rebooting excessively sounds like a connection and signal strength issue to me. Either wait here for further advice to help diagnose, or call in a fault. It is unlikely in the extreme that your Hub 3 is faulty and Hub 4 probably won't improve matters.
