on 04-10-2022 07:49
My 2.4ghz network shows as active however it does not appear available on any device to connect to I have followed all sorts of resets and changing the connection name/wifi settings/router reboot but no joy. I have only realised this is the problem as I tried to connect a second device that only supports 2.4ghz (first one stopped worked when I had vm installed I thought it was the device but now makes sense it’s the router) it must be a fault on the hub 4 and likely need a engineer or replacement hub? please can you help?
the two devices I’m trying to connect are a Sonos one Alexa speaker and a ring gen 2 doorbell
on 04-10-2022 14:06
on 06-10-2022 15:26
Hey james_m93, thank you for reaching out and a warm welcome to the community I am sorry to see you are having some connection issues.
I would like to look into this for you via PM, I am going to send you a PM.
Please can you look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
