on 29-06-2022 19:36
All of a sudden my hub 4.0 has completely bricked, its not visible for WiFi connections it will not reset and is not connecting to the network so even Virgin can't get into it, seems I have to wait 5 days for a tech when it's pretty clear the hub has died, I'm willing to bet the tech will not have a replacement hub and will need to wait a further 3 days for a replacement to arrive and be expected to pay the full bill still.
on 29-06-2022 20:50
Just to check, have you tried a pin-hole reset by holding down the button until the light band turns off and then back on?
on 30-06-2022 18:53
No matter how long I press the white light band remains in tact, when switching off and on again the light band fires straight up in solid white
on 30-06-2022 22:05
No worries, that is rather odd...
When restarting the hub should fire up solid and then start attempting to connect and then start flashing until it connects or fails to. Are all your connections secure and finger tight?
If so then it sounds like you've said in that the hub has passed on and you need a new one.
on 01-07-2022 06:29
Everything plugged in nice and snug, it's like the internal memory has failed or something.
on 03-07-2022 12:47
Hi @Bryanlight,
Thank you for your posts and welcome back to our community forums. We're here to help.
I am so sorry to hear that you've been having some issues with your Hub 4 recently. I'm confident that the technician will be able to identify and resolve the fault you're experiencing. Please do let us know how the visit goes.
on 07-07-2022 15:34
Held it down for over 5 minutes and light stayed on, internal memory has failed and is rubbish lamp instead of a rubbish router, been replaced now but apparently it was my fault it failed despite it being sat un modem mode for the last 2 years completely unmoved.
on 09-07-2022 16:22
Hi Bryanlight
Thanks for coming back to me. Has the issue been fixed by replacing the router?
Kind regards,
