on 17-08-2021 23:02
My works computer will not connect to router despite punching in password Cannot find network switch it off and still says the same why any body help
on 18-08-2021 01:11
on 20-08-2021 10:06
Hello Stratford1935
Thanks for you post
Have you been able to get this resolved yet
Also are you having the same issue with any other devices
From the reply by @jbrennand, Ir does seem like it is your works VPN that is causing this issue
Gareth_L
