08-09-2021 15:33 - edited 08-09-2021 15:35
Hub 3 with pretty much default settings bar the password.
Archer C2 to be used as a wireless bridge to connect PC with Ethernet cable from Archer.
I had this working fine, it is not hard: Turn on wireless-bridge mode on Archer, select wireless network to be bridged, turn off Archer DHCP, job done.
https://www.tp-link.com/uk/support/faq/440/
This failed for some reason and I cannot get it to work again. Is there anything that may have changed on the Hub 3 that may have caused this? I am sure there are loads of you out there doing this as it "just worked", but now, seems broke,
Thank you
RS
on 08-09-2021 15:36
on 08-09-2021 16:11
It worked fine before. The Hub wireless is fine. PC has much better connection using the archer rather than a dongle. Just want to reinstate the archer,
Thank you,
RS
on 08-09-2021 16:13
on 08-09-2021 16:28
Yep,
It just seems so silly that I think I am missing the obvious. I am now trying the set up on a different hub3
RS
on 08-09-2021 17:00
on 08-09-2021 17:02
@RockySpears wrote:Yep,
RS
What different Hub3 - you can only have one Hub connected to the network on one VM account. Do you mean on someone elses account and Hub?
on 08-09-2021 17:10
Yes, different account. Set the Archer up for my son, all worked fine for 6 - 8 months, maybe more.
Now nothing. tried to set up with my router and I end up with the 169 ip address, can't ipfconfig renew because it cannot find the DHCP server, ie the archer is not bridging to the hub for whatever reason,
Software version 9.1.1912.304
RS
on 08-09-2021 17:14
on 08-09-2021 17:18
The archer is 192.168.0.2 to avoid collision with the hub.
I need the archer to connect to the Hub via wireless then the PC from the archer via cable as the PC wifi connection seems poor, but with the Archer doing the bridging all was good. ,
RS
