on 21-09-2022 10:21
I have tried all sorts available on this website but cannot login using my admin password. I think my hub is faulty and would like to know how I can request a new router please.
Thank you
on 21-09-2022 10:51
There should be two passwords on the bottom of the hub, the WiFi one and the settings one.
on 21-09-2022 13:57
Yes, I understand.
I am trying to reset it with setting password because the connection keep dropping and having issues such as video calls and zoom meeting.
on 23-09-2022 14:14
Hi @Pyae,
Welcome to our community forums and thank you for your first posts.
Sorry to hear you have been experiencing intermittent service. We can understand the frustration caused and we want to best help. Just to clarify, do you get this service on wired or wireless devices? How long has this been ongoing for? Have you checked here for a local fault? virg.in/service. You may also find the following link useful https://www.virginmedia.com/help/broadband/set-up-broadband under the title How to configure advanced settings on the Hub
on 26-09-2022 16:04
I have this problem for about 3 weeks. Connection keep dropping so issues with video calls and zoom.
No local issues.
Cannot get into setting using setting password. Tried resetting the hub but did not work.
I believe it is the router's fault.
How can I get virgin to check it and replace it please?
thanks
on 28-09-2022 16:47
Hi @Pyae,
Thank you for coming back to us about this issue. I have been able to look into our systems to investigate your issue further.
I can see that you're having some issues with your upstream and downstream power levels which could be responsible for your ongoing connection issues. As we cannot resolve this issue remotely, we would need to arrange for a technician appointment to resolve this.
I will send you a Private Message to confirm a few details. Please keep an eye out for a purple envelope at the top right corner of your Forum page. I will be in touch soon.
Thank you.
