on 11-10-2021 23:22
Just set my new router to be modem only but could not get into in to it to make more changes despite cable to a DSL router.
So pressed reset and held for 10 seconds it does something with the main light purple and thats it still cannot get into it and I am beginning to think it is a BUG unless some one else knows other wise.
Blaster router is beginning to annoy me 😞
Any one any ideas as I cannot find any kind of a manual and getting close to ordering a Asus RT-AC86U but I do have a phone line 😞
Answered! Go to Answer
on 12-10-2021 00:24
A 10 second reset won't work.
Keep the hub switched on and disconnect any ethernet connections, then push the reset button firmly and keep it pressed in for a full minute.
Wait around 10 minutes and it should revert to factory settings. You can now reconnect the ethernet cables.
If you previously changed your router password it won't work and you will have to use the one printed on the sticker on the router. You can always change it again by going into the settings
on 11-10-2021 23:55
on 12-10-2021 00:24
on 12-10-2021 12:24
I am going that way BUT I know that I will still need the VM hub if only for the phone line but I am sonsidering using a line splitter (as was used for my TV antenna) to connect to VM cable linked to the Hub 3 AND the AC86U.
I am "assuming" here that will work ?
Vince
on 12-10-2021 12:25
on 12-10-2021 14:40
on 24-02-2022 14:51
Done so, thanks.
