on 04-09-2022 10:27
For the last week my hub 3 has a permanent red light. It's been in the same position since installation years ago.
It's not overheating, it's in an open, well ventilated, position.
I've disconnected/reconnected. Still red.
How do I get virgin to supply me with a new router?
Martin de la Fosse
on 04-09-2022 12:11
Hi there @18wpa
Thank you so much for your post and welcome back to the community forums!
I am so sorry to hear that you are facing this issue with your Hub!
Can I just check have you performed a full factory reset? To do this push a pen etc into the rest hole at the back of the Hub and hold it in for 30 seconds.
Thank you.
on 04-09-2022 13:00
Yes. First thing I tried. Just tried again. Still have red light
on 04-09-2022 13:09
on 04-09-2022 19:36
Disconnected/reconnected hub, still red light.
Rang 'india' support. All I got was turn off hub, and reset. Nothing else. How do I get a new hub?
on 04-09-2022 19:47
Have no connection, this is from phone. Sort this out, virgin media. India support was switch off, reset. Already done all that
Have also discounted and relocation hub. No connection
on 04-09-2022 19:49
If not sorted, work connection, I will look at leaving virgin
on 07-09-2022 08:19
Thank you for keeping us updated 18wpa.
We may need to get an engineer out to change the hub.
What I will do is private message you now so I can confirm your details and pass data protection.
^Martin
