on 05-07-2022 10:53
My hub 3 is showing a red power light instead of the usual white power light. It is solid red but the hub is not overheating and is kept in open space. Have rebooted the hub couple of times but no luck.
05-07-2022 10:55 - edited 05-07-2022 10:55
Please do a pin hole reset and report back. VM will get to your post shortly.
on 05-07-2022 11:34
Hi simitm,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm very sorry to hear you're having some issues with your Hub displaying a red light. Just to double check, is the Hub currently in modem mode? If so then the light will be a magenta colour but can look quite red. This is perfectly normal. If it's not then please follow the below steps:
If the issue remains, pop back here and let us know. We can then either arrange a replacement or an engineer to visit to swap out the Hub.
