on 05-08-2021 09:55
My Hub reboots itself about 4 times a week, which appears not bad compared to some people. Each time I confirm that it has rebooted by logging in to the Hub and looking at Admin/Info.
System up time | : 2 days 0h:10m:14s |
I am running in modem mode with an Asus RT-AX88U providing the Wi-Fi. The problem I have is with my alarm system. I am unable to connect via my phone to the alarm system until I reboot the Asus router.
1 | 138750000 | 4.5 | 38 | 256 qam | 1 |
2 | 146750000 | 4.5 | 38 | 256 qam | 2 |
3 | 154750000 | 4.5 | 38 | 256 qam | 3 |
4 | 162750000 | 4.1 | 38 | 256 qam | 4 |
5 | 170750000 | 4 | 38 | 256 qam | 5 |
6 | 178750000 | 3.5 | 38 | 256 qam | 6 |
7 | 186750000 | 3.5 | 38 | 256 qam | 7 |
8 | 194750000 | 3.2 | 38 | 256 qam | 8 |
9 | 202750000 | 3 | 38 | 256 qam | 9 |
10 | 210750000 | 3 | 38 | 256 qam | 10 |
11 | 218750000 | 3 | 38 | 256 qam | 11 |
12 | 226750000 | 3.2 | 38 | 256 qam | 12 |
13 | 234750000 | 3.2 | 38 | 256 qam | 13 |
14 | 242750000 | 3 | 38 | 256 qam | 14 |
15 | 250750000 | 3.2 | 38 | 256 qam | 15 |
16 | 258750000 | 3.4 | 38 | 256 qam | 16 |
17 | 266750000 | 3.4 | 38 | 256 qam | 17 |
18 | 274750000 | 3.5 | 38 | 256 qam | 18 |
19 | 282750000 | 3.4 | 38 | 256 qam | 19 |
20 | 290750000 | 3.5 | 38 | 256 qam | 20 |
21 | 298750000 | 3.5 | 38 | 256 qam | 21 |
22 | 306750000 | 3.5 | 38 | 256 qam | 22 |
23 | 314750000 | 3.7 | 38 | 256 qam | 23 |
24 | 322750000 | 3.7 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 34 | 0 |
2 | Locked | 38.9 | 37 | 0 |
3 | Locked | 38.9 | 21 | 0 |
4 | Locked | 38.6 | 24 | 0 |
5 | Locked | 38.9 | 32 | 0 |
6 | Locked | 38.6 | 28 | 0 |
7 | Locked | 38.9 | 16 | 0 |
8 | Locked | 38.6 | 16 | 0 |
9 | Locked | 38.9 | 10 | 0 |
10 | Locked | 38.9 | 20 | 0 |
11 | Locked | 38.6 | 11 | 0 |
12 | Locked | 38.6 | 15 | 0 |
13 | Locked | 38.6 | 49 | 0 |
14 | Locked | 38.6 | 11 | 0 |
15 | Locked | 38.9 | 20 | 0 |
16 | Locked | 38.9 | 36 | 0 |
17 | Locked | 38.6 | 35 | 0 |
18 | Locked | 38.9 | 18 | 0 |
19 | Locked | 38.9 | 21 | 0 |
20 | Locked | 38.9 | 25 | 0 |
21 | Locked | 38.9 | 40 | 0 |
22 | Locked | 38.9 | 33 | 0 |
23 | Locked | 38.9 | 41 | 0 |
24 | Locked | 38.9 | 47 | 0 |
1 | 39400000 | 43.5 | 5120 | 64 qam | 4 |
2 | 46200000 | 43.3 | 5120 | 64 qam | 3 |
3 | 60300000 | 42.8 | 5120 | 64 qam | 1 |
4 | 53700000 | 42.8 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Network log to follow as the message exceeded 20,00 characters.
on 05-08-2021 09:56
03/08/2021 09:41:21 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/08/2021 00:51:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/08/2021 19:11:38 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/07/2021 03:39:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/07/2021 19:07:29 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/07/2021 22:07:50 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/07/2021 17:14:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/07/2021 06:15:48 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/07/2021 07:21:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/07/2021 06:22:14 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/07/2021 07:02:5 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/07/2021 07:34:46 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/07/2021 10:23:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/07/2021 09:51:12 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/07/2021 00:37:51 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/07/2021 23:27:25 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/07/2021 21:34:41 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/07/2021 15:03:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/07/2021 07:15:55 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/07/2021 16:07:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 05-08-2021 14:05
on 05-08-2021 22:19
Thanks, here is the link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a0ac1a92a87e28548aa2a1545c059bacd09af938
on 06-08-2021 14:41
on 06-08-2021 17:02
Thanks John, I have enabled the ICMP on the Asus router.
Cheers Andrew
on 07-08-2021 09:24
The hub 3 rebooted at 9:03, this can be seen on the graph.
on 07-08-2021 14:42
on 07-08-2021 22:49
No I didn't reboot it.
The network log shows nothing useful around the time of the reboot, just my login to check it had rebooted.
07/08/2021 14:59:52 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/08/2021 09:05:26 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/08/2021 02:24:59 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 08-08-2021 14:45
