scopey
Hub 3 port forwarding on port 554 for cctv blocked
Can anybody help please?
I am unable to view my CCTV from my mobile using 4G, when I'm on my wireless it works fine.
I can view my cctv from another network using the web browser so I know access is not blocked on port 80.
I have setup port forwarding on both TCP & UDP port 554 as per instructions for my NVR for CCTV.
Using 2 different port checkers to see if port 554 is open shows port 554 is blocked even though I have setup port forwarding for port 554.
Any help would be appreciated.
Thanks .
  • 12.02K
  • 442
  • 1.07K
Re: Hub 3 port forwarding on port 554 for cctv blocked
Hub 3 has bugs for port forwarding so you need to use modem mode and get your own router with 1Gb ports
scopey
If I got another router would that affect virgin tv?
  • 12.02K
  • 442
  • 1.07K
No you can connect the TV box Ethernet to the new router.
You connect the new router to the hub in modem mode.
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
