Howard2000
Hub 3 port connections
Ok so I have run a CAT7 Ethernet cable from one room which has a V6 box & the Hub 3 to another room with a TiVo box in it. In the room with the TiVo box I have added a TP 5 port switch as want to connect the smart tv up too.
whilst I have had it working the whole box to box so I can view recordings from one room on the other box & had the smart tv connected it seems patchy as if I go back to it the settings aren’t there & sometimes it connects & sometimes it doesn’t. The lights on the back of the port switch are on but was wondering if there is something else I need to do?
  • 1.41K
  • 75
  • 139
Re: Hub 3 port connections
Hi Howard,
Welcome to the forums and for your first post 🙂
Sorry that you're having issues with your set up - is it streaming from box to box that you're having the issue with? I am sorry but I got a bit lost with your post - apologies.
Cheers
Katie - Forum Team
  • 4.45K
  • 299
  • 744
Roger_Gooner
Community elder
I think the OP has something like this.
Hub 3.0 |--> V6
              |--> TP-Link switch |--> TiVO
                                             |--> TV
It's worth powering off the V6 and the TiVo, waiting several minutes and rebooting.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 591
  • 10
  • 38
Forum Team (Retired) Ben_N
Hi Howard2000,
How are things looking at the moment?
Has restarting helped with this?
Ben_N
