on 08-09-2022 12:32
I'm also having problems with this. Very very many hours trying to get a Hub 3 to act as a modem, so that I can install a Mesh wifi system tp deco AX3000 X60.
The steps to get in and change the settings of the Hub 3 to a modem are OK (it's a bit of a pain having to by a connector so that I can then connect to a Mac, but so be it). The steps to control the X60, via the app work ok.
What happens is, and I don't quite know exactly why yet, I convert over to modem and after the reboot the Hub 3 goes to a red light and my only way out of that is to reboot, back to wireless mode and restart the whole process. Trying to isolate and see if it's something about trying to sort the deco (on wifi as your steps have been very helpful about) or a fundamental modem problem.
If I run the Hub as a modem can I still use the ethernet ports/ more than one? I've seen one comment that as a modem I can only use one port, to the deco, and if I want to run anything else eg a PS, then I've to run that from the deco. Is that true.
Thanks in advance.
Answered! Go to Answer
on 08-09-2022 14:54
on 08-09-2022 14:09
@Kellyfamily wrote:What happens is, and I don't quite know exactly why yet, I convert over to modem and after the reboot the Hub 3 goes to a red light
yes its meant to be red
@Kellyfamily wrote:If I run the Hub as a modem can I still use the ethernet ports/ more than one?
no
on 08-09-2022 14:54
on 08-09-2022 14:56
OMG it could be that simeplmy deco light goes red too, so I'd assumed there was a problem at the modem end. But your answer's been very helpful. it's work in progress, slow progress.
on 09-09-2022 00:05
Thanks John, I thought I’d followed these instructions to the letter last night. I’m going to try again. Still not working but I’m also the variable in the equation.
Q - I’m reading, & in this thread, that I can only have one Ethernet cable out from Hub 3, it will have to go to deco box. So if I want to run a cable to my virgin TV/ tivo box do I have to run that from deco or can I still run it from Hub 3 in modem mode? That would be 2 cables, and breach the 1 cable rule…
on 09-09-2022 02:54
Thank you so much. Worked just as you said.
Kudos friend.
on 09-09-2022 09:09
on 09-09-2022 10:27
on 09-09-2022 10:32
on 21-10-2022 12:13
I seem to be having the same problem now with my Deco P9.
Yesterday we had a service outage in our area and at the same time renewing my contract and upgrading to the M200. When services resumed in my area, i noticed my Deco was showing Red.
I have done everything from
1) rebooting all
2) replacing cables
3) factory resetting Decos
4) factory resetting Home Hub (and putting it back in Modem mode again)
5) following your instructions below that others have had success with.
unfortunately, I'm still having the same issue. When i look at the WAN Details in the decom app, i does not show me anything. I placed the HH back in router mode and i have internet connectivity however, going back to modem mode and the deco turns red again and stays red no matter what i do with empty WAN details.
If anyone can offer some assistance, i would GREATLY appreciate it.
PS also spoke to virgin but we all know how that goes...
