on 11-01-2022 18:47
Since the planned maintenance work on Monday 10th Jan, my Hub 3 has stopped working when in modem mode.
The device displays a constant red light, its in a ventilated place and is cool to touch, and if i do a hard reset and return it back to being a router it connects to the internet, but if i switch it back in to modem mode, i get a flashing white light, followed by a flashing green light, then green and the two arrows, then red arrows and finally a solid red light.
No issues prior to the 10th, and ive read somewhere on the help pages only certain hubs are modem mode compatible, how can i check mine is?
on 11-01-2022 19:12
@markytaz wrote:Since the planned maintenance work on Monday 10th Jan, my Hub 3 has stopped working when in modem mode.
What router do you have attached to the hub?
And is there anything else attached to the hubs Ethernet ports other than the router?
on 11-01-2022 20:41
Asus router nothing else. Even tried direct in to my laptop and no internet ipaddress is a 169 address
on 11-01-2022 21:03
on 11-01-2022 21:06
on 12-01-2022 12:10
Tried all those options, hence removing my router from the Hub3 and simply connecting directly to my laptop. When i do a ipconfig /release and renew i still get the 169 address that implies no connectivity.
on 12-01-2022 12:11
Yes i even got an email from Virginmedia stating the work was completed and their service had resumed
on 12-01-2022 12:40
on 12-01-2022 17:53
Still no joy red light no internet
on 12-01-2022 18:27
Hi @markytaz,
Thank you for your posts and welcome to our community forums, we're here to help.
I am so sorry to hear you're having a bit of trouble with your router recently and are getting a red light. If you haven't done so already, can you please follow these steps in this order and let us know if it helps at all?
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
