titch53
Hub 3 losing internet connection
Here are my logs
Network LogTime Priority Description
2019-02-02 12:36:50.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-04 00:01:22.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-04 00:01:22.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-04 00:01:23.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-04 00:01:26.00Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-04 00:04:51.00criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 07:07:24.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 07:09:18.00criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 07:09:53.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 07:10:48.00criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 07:11:19.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-09 04:37:47.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-09 09:54:51.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-09 20:22:47.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-10 03:31:00.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-10 04:15:17.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-10 06:11:07.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-10 08:11:32.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-11 07:19:53.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12430000000.440256 qam14
23230000000.238256 qam24
33150000000.438256 qam23
43070000000.540256 qam22
52990000000.738256 qam21
62910000000.438256 qam20
7283000000040256 qam19
82670000000.240256 qam17
9259000000040256 qam16
102510000000.240256 qam15
112350000000.540256 qam13
122270000000.540256 qam12
132110000000.740256 qam10
14203000000140256 qam9
151870000001.440256 qam7
161790000001.240256 qam6
171630000001.440256 qam4
181550000001.440256 qam3
191470000001.440256 qam2
20275000000038256 qam18
212190000000.740256 qam11
221950000001.240256 qam8
231710000001.240256 qam5
241390000001.540256 qam1
1Locked40.3430
2Locked38.99650
3Locked38.97670
4Locked40.34890
5Locked38.94430
6Locked38.92630
7Locked40.31540
8Locked40.3940
9Locked40.3890
10Locked40.3630
11Locked40.3260
12Locked40.3290
13Locked40.3420
14Locked40.3140
15Locked40.3560
16Locked40.3460
17Locked40.3380
18Locked40.3960
19Locked40.3210
20Locked38.91110
21Locked40.9300
22Locked40.9310
23Locked40.35960
24Locked40.3270
13020000044.3512016 qam70
22360000043.5512016 qam71
1ATDMA0010
Do I need an engineer or is the hub 3 just not up to it and a new router is the answer. Thanks.
  • 11.37K
  • 405
  • 1K
Re: Hub 3 losing internet connection
Your signals look fine.
Setup a BQM
run cmd
ping -n 200 194.168.4.100
