thrustmaster01
Hub 3 login
Cant login to the hub 3 using any web browser says password is incorect
Have reset router countless times still same error
Can authorise wifi using that password but cant log on to router using other password
  • 19.28K
  • 1.68K
  • 4.22K
Re: Hub 3 login
When resetting hub it hold for good 30 seconds, don't reboot hub at any stage and are if can then login, and would need to use the and settings password on hub to login into it
Click to learn more about VIP
Use Kudos to say thanks
thrustmaster01
Re: Hub 3 login
thanks very much for that it worked and its also cured the flashing wifi light which was annoying too
  • 19.28K
  • 1.68K
  • 4.22K
Re: Hub 3 login
always use a bit of black tape 🙂
