  • 7
lutzky
Hub 3 keeps rebooting
Hi all,
Got a Hub 3 last week, and it works well other than the fact it keeps rebooting. Upon reboot, it'll flash the light green for a bit ("updating", as it were), but I'm pretty sure it's too frequent to actually be updating. Today I had two reboots, spaced ~3 hours apart.
For the 24 channels in Downstream, I get a "Power(dBmV)" value scatter between 3 and 9, with SNR (dB) of 38-40. I'm not sure if this is at all relevant.
Also, there doesn't appear to be any user-accessible log I can see for reboot reasons.
  • 5.48K
  • 427
  • 917
Superstar
Re: Hub 3 keeps rebooting
Please post your full stats and network log. The upstream data can be particularly revealing for problems.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
  • 7
lutzky
Device info:
Virgin Media Hub 3.0 device information
The information below shows current status of this Virgin Media Hub 3.0.
Standard specification compliant:DOCSIS 3.0
Hardware version:4.01
Software version:CH7465LG-NCIP-6.12.18.25-2p4-NOSH
Cable MAC address:**:**:**:**:**:**
Cable modem serial number:DDAP52840266
System up time:0day(s)0h:4m:54s
Network access:
Allowed
Network log, which I just realized was there, appears illuminating:
16-06-2019 20:15:56warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:15:56criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:15:16warningMIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01-01-1970 00:01:20noticeCable Modem Reboot - due to power reset;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:05:50warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:05:50criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:05:10warningMIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:05:02noticeIllegal - Dropped FORWARD packet: src=192.168.0.251 MAC=**:**:**:**:**:**;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01-01-1970 00:01:19noticeCable Modem Reboot - due to power reset;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:01:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:00:25warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 20:00:25criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 19:59:45warningMIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 18:35:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 16:42:20warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 16:42:20criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 16:41:41warningMIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16-06-2019 13:53:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Here's the super weird part - I run grafana on a machine I have on this network (I have IPv4 port forwarding pointed at it), and - this sounds incredibly unlikely - but it appears that accessing grafana causes the router to reboot. It sounds pretty crazy, as the connection is over HTTPS and Grafana has no business even talking to the router, but these "critical; broadcast maintenance requests" have me suspecting that Grafana is triggering a router reboot. Is that even possible?
  • 7
lutzky
Tried again this morning, and lo and behold - connecting to Grafana causes the router to restart again. I believe that the relevant log message that is shown is "Cable Modem Reboot - due to power reset" (at Unix Epoch, 1970-01-01) and that the following messages are just the router going back online.
While testing, I found that this happens not just with Grafana, but also with Organizr (a tabbed display for the various things I run on my system) that I have made available, see below.
Some more details about my setup:
I have a Linux machine running on 192.168.0.10 internally, running a reverse proxy (traefik) on ports 80 (for local access) and https on port 8111 (for remote access). Port 8111 is externally visible as port 443, and I have a dynamic DNS domain hooked up to my external IPv4 address; let's call this domain somedomain.com.
Grafana is accessible either by going to http://192.168.0.10/grafana (redirected by traefik, no https) or by going to https://somedomain.com/grafana (also redirected by traefik on port 8111, with https). The https connection is protected by HTTP Basic Auth. Similarly, going to http://192.168.0.10/ or https://somedomain.com/ gets to Organizr.
When accessing these services through the external IP address (over port 8111, using https), after about 5MB of transfer, the router reboots. I did not have this issue with my previous router (I believe it was a Technicolor TC7200). I don't seem to have any other high-bandwidth issues, e.g. netflix streaming works just fine.
Any advice?
17-06-2019 08:58:29
warning
[**:**:**:**:**:**][DFS] Radar signal detected, DFS sequence applied, channel changed from 124 to 104
17-06-2019 08:52:26
critical
17-06-2019 08:52:26
warning
17-06-2019 08:51:54
critical
17-06-2019 08:51:46
warning
01-01-1970 00:01:19
notice
  • 7
lutzky
Additional debug info, if at all relevant:
Acquired Downstream Channel(Hz)650000000Locked
Ranged Upstream Channel(Hz)53600000Ranged
Provisioning StateOnlineOperational
1650000000738256qam20
2187000000340256qam2
3195000000240256qam3
4203000000340256qam4
5211000000340256qam5
6219000000340256qam6
7227000000340256qam7
8235000000340256qam8
9474000000538256qam11
10482000000538256qam12
11490000000638256qam13
12498000000638256qam14
13506000000638256qam15
14514000000640256qam16
15522000000638256qam17
16530000000638256qam18
17538000000640256qam19
18179000000240256qam1
19658000000838256qam21
20666000000838256qam22
21674000000738256qam23
22682000000838256qam24
23690000000838256qam25
24698000000838256qam26
1Locked38.9832084233760
2Locked40.9462054331296
3Locked40.3662054383680
4Locked40.9462054376734
5Locked40.3662054382165
6Locked40.3662054326156
7Locked40.3662054385644
8Locked40.9462054393870
9Locked38.9832054331610
10Locked38.9832054398470
11Locked38.9832054406671
12Locked38.6052054431017
13Locked38.6052054440123
14Locked40.3662054448475
15Locked38.6052054409407
16Locked38.9832054454340
17Locked40.3662054470120
18Locked40.94620544977213
19Locked38.98320544824212
20Locked38.6052054511375
21Locked38.9832054475550
22Locked38.6052054531686
23Locked38.6052054540047
24Locked38.6052054459120
153600000435.12064qam10
260200000415.12064qam11
332800000395.12064qam7
446000000405.12064qam9
539400000415.12064qam8
12.00010
22.00001
32.00000
42.00000
52.0000
0
General Configuration
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
Allowed
10
Enabled
DOCSIS 3.0
CH7465LG_cm_res003_v4-sip.bin
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateSFIDMax Traffic RateMax Traffic BurstMin Traffic RateSFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
254681170
10485760 bps
16320 bytes
0 bps
254681169
160000 bps
3044 bytes
12000 bps
254681168
256800000 bps
42600 bytes
0 bps
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling TypeSFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling TypeSFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
254672980
2097152 bps
16320 bytes
0 bps
16320 bytes
Best Effort
254672979
160000 bps
3044 bytes
12000 bps
1522 bytes
Best Effort
254672975
25680000 bps
42600 bytes
0 bps
42600 bytes
Best Effort
  • 7
lutzky
OK, I'm closing this thread in favor of this one, with a better title and a more precise description of the problem:
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-3-crashes-when-accessed-through-externa...
