HI
Thought I'd give this a go... cant seem to get it resolved?
The connection is stable then just randomly starts to drop and the hub starts doing its reboot cycle
We have had engineers out twice 1 replaced the standard cables , connection and wall box bit and pieces next replaced the router
All ok for about 5 days then it started again I switched plugs thinking it may be with the plug
details added below from reading the forum... if theres anything else let m know any help will be greatly appreciated... thanks in advance.
12/06
11/06
10/06
09/06 -- 6pm was a reboot/unplug
08/06
exceeded 200000 characters??? removed some tables - let me know if required I will try add
Time | Priority | Description |
11/06/2021 22:31:7 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
11/06/2021 19:56:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
11/06/2021 16:45:9 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 20:13:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 17:03:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 17:02:44 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 03:50:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
09/06/2021 13:27:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
09/06/2021 01:58:22 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
08/06/2021 16:51:15 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
08/06/2021 16:22:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
07/06/2021 11:35:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
06/06/2021 08:42:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
05/06/2021 04:28:3 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
05/06/2021 00:34:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 15:32:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 13:10:27 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 11:55:42 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 11:55:42 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 10:57:55 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
