on 11-09-2022 13:19
Hi everyone,
rhis may be an easy fix but am not sure what to do next.
We have had a hub 3 for over a year now and we have had ok internet and are on the Volt M200 (although no noticeable difference from M100 noted). We do have a lot of wifi devices connected - phones, iPads, computers, printer, camera, catflap etc and I work from home - I have one belkin wifi signal boost under my desk and for a while has been fine.
recently I have noticed the hub has a permanent orange light on, we get intermittent drops (when I’m working from home) and signs the network isn’t coping as we use video calling a lot and it regularly drops out or freezes when on video.
Usually my little Belkin repeater lights up blue but for a while has been on orange indicating the signal is crap (we have a small house but thick walls)
I have tried to reset for 60 seconds and it initially comes up green but then goes back to orange.
the app can’t find the router despite trying for over a few weeks, reinstalling etc etc
despite all this even though we have an orange light wifi still works all be it not great
help?
on 11-09-2022 13:59
on 11-09-2022 14:33
Thanks John, I had deleted and reinstalled the app and I still get the same message of it not being able to find the app and the router is still on orange. When I reset it, it initially goes green so I know it isn’t an led malfunction
on 11-09-2022 15:52
on 13-09-2022 16:10
Hello Missdgear,
Just a quick message to see if you have any images of the Hub?
Is it hot to touch?
In a well ventilated place away from any direct source of heat?
Gareth_L
on 13-09-2022 16:27
Hi Gareth,
It had been hot to the touch - a few weeks ago but isn’t now - I have been in contact with Virgin and they have confirmed there is a fault in my area which can apparently cause the issues I have had. They say it should be fixed by 21st September !!! which doesn’t really help as don’t have access to my NAS system, which I use daily 😞
