Hub 3 ip range?
gilbo2
Do the latest Hub 3’s allow you to change the LAN ip range?
(just signed up to M125 so assume this is what I’ll get)
1 ACCEPTED SOLUTION
Accepted Solutions
nope you need your own router
8 REPLIES 8
gilbo2
Thank you, I feared as much.
Do any of the VM hubs allow the ip range to be changed?
nodrogd
On the residential service, no. I think the ones supplied for Virgin Business services do.
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
gilbo2
Thanks for the quick reply. Looks like I will have to get my own router then as previously suggested 😞
I do have an old Netgear WNDR3400 which will do for now but limits my Ethernet connections to 100mb.
Hero
For about £40 or less a TP-LINK Router is available from Amazon with decent Wi-Fi and all 1Gb/s LAN & Network ports.
gilbo2
I'll take a look at those, thanks. I don't need Wi-Fi as I have BT Whole Home discs, so I'll maybe find something even cheaper, or take the Wi-Fi as a bonus 🙂
Hero
Make quite sure ( do not assume) the BT Whole Home discs are a full retail product that you can re-configure to work with another ISP.   A Wi-Fi Router is a bonus ... it gives you one more Wi-Fi AP in your home.
gilbo2
Good point, they are supposed to work with any ISP but will check first.
