  • 37
tkdsouth
Hub 3 forgets all settings when power goes off
So you set up you new name for your network and you guest network and change all the passwords.
Then the power goes out and all the setting are back to default why is this? It never used to happen.
  • 12.45K
  • 471
  • 1.11K
Re: Hub 3 forgets all settings when power goes off
Its a bug if you want settings to stick get your own router with 1Gb ports and use the hub in modem mode.
You can put the hub in modem mode with a PC then pull the plug to see if it resets to router mode.
  • 37
tkdsouth
If it is a bug does that mean it has a fix on the way in a firmware update?
  • 12.45K
  • 471
  • 1.11K
Not for a long time if ever...
  • 37
tkdsouth
It seems not matter what I did the problem wouldn’t go away, we had to have a new box in the end and things are back to normal now.
  • 14
torikoos
My super hub is doing the exact same thing, a restart (also after a software update) causes the thing to default to the factory settings, so having to log in again , change the name and passwords so that all devices work again, then it does the same again a few days later... (or indeed after a power interruption)...
Virgin, sort this out!
