on 17-08-2021 11:23
I am using my Hub 3 in modem mode and it is intermittently dropping connection many times a day. I have looked at the network log, which is showing the following:
17/08/2021 10:11:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 10:11:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 10:10:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 10:08:26Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
17/08/2021 09:59:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 09:56:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 09:32:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 09:24:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 06:41:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 06:41:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 05:51:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 05:51:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 05:21:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 05:21:18criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 04:47:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 04:46:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 04:45:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2021 04:45:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Several reboots tried. Any help appreciated.
Answered! Go to Answer
on 17-08-2021 14:13
on 17-08-2021 12:16
on 17-08-2021 12:45
Acquired Downstream Channel (Hz) | 139000000 | Locked |
Ranged Upstream Channel (Hz) | 53699926 | Locked |
Provisioning State | Online |
1 | 139000000 | 7 | 38 | 256 qam | 1 |
2 | 147000000 | 6.9 | 38 | 256 qam | 2 |
3 | 155000000 | 7.1 | 38 | 256 qam | 3 |
4 | 163000000 | 6.8 | 38 | 256 qam | 4 |
5 | 171000000 | 6.5 | 38 | 256 qam | 5 |
6 | 179000000 | 6.3 | 38 | 256 qam | 6 |
7 | 187000000 | 6 | 38 | 256 qam | 7 |
8 | 195000000 | 5.9 | 38 | 256 qam | 8 |
9 | 203000000 | 5.6 | 38 | 256 qam | 9 |
10 | 211000000 | 5.4 | 38 | 256 qam | 10 |
11 | 219000000 | 5.1 | 38 | 256 qam | 11 |
12 | 227000000 | 5.1 | 38 | 256 qam | 12 |
13 | 235000000 | 5.1 | 38 | 256 qam | 13 |
14 | 243000000 | 4.4 | 38 | 256 qam | 14 |
15 | 251000000 | 4.4 | 38 | 256 qam | 15 |
16 | 259000000 | 4.8 | 38 | 256 qam | 16 |
17 | 267000000 | 4.5 | 38 | 256 qam | 17 |
18 | 275000000 | 4.9 | 38 | 256 qam | 18 |
19 | 283000000 | 5.5 | 38 | 256 qam | 19 |
20 | 291000000 | 5.3 | 38 | 256 qam | 20 |
21 | 299000000 | 5.4 | 38 | 256 qam | 21 |
22 | 307000000 | 5.8 | 40 | 256 qam | 22 |
23 | 315000000 | 6 | 38 | 256 qam | 23 |
24 | 323000000 | 5.4 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 50686831 | 21252304 |
2 | Locked | 38.9 | 29039790 | 13994137 |
3 | Locked | 38.9 | 39120435 | 17163723 |
4 | Locked | 38.9 | 50696739 | 28566982 |
5 | Locked | 38.9 | 25250628 | 12273690 |
6 | Locked | 38.9 | 48383464 | 20018203 |
7 | Locked | 38.6 | 34407976 | 9511726 |
8 | Locked | 38.9 | 24448808 | 4571214 |
9 | Locked | 38.9 | 22172227 | 3471967 |
10 | Locked | 38.9 | 24137855 | 1178145 |
11 | Locked | 38.9 | 27356027 | 1412176 |
12 | Locked | 38.9 | 23546609 | 4694699 |
13 | Locked | 38.6 | 24371415 | 4349998 |
14 | Locked | 38.6 | 26060800 | 1127897 |
15 | Locked | 38.9 | 25271443 | 1071921 |
16 | Locked | 38.6 | 23061906 | 3235295 |
17 | Locked | 38.9 | 18489957 | 6934673 |
18 | Locked | 38.9 | 16809664 | 4576280 |
19 | Locked | 38.6 | 12064471 | 201233 |
20 | Locked | 38.9 | 14163406 | 460726 |
21 | Locked | 38.6 | 10546191 | 3521502 |
22 | Locked | 40.3 | 8608004 | 2507544 |
23 | Locked | 38.9 | 5346253 | 98815 |
24 | Locked | 38.6 | 7012860 | 107542 |
1 | 53699926 | 41.5 | 5120 | 64 qam | 6 |
2 | 60300000 | 42 | 5120 | 64 qam | 5 |
3 | 46200000 | 40.8 | 5120 | 64 qam | 7 |
4 | 39400000 | 40.5 | 5120 | 64 qam | 8 |
1 | ATDMA | 0 | 0 | 72 | 0 |
2 | ATDMA | 0 | 0 | 52 | 2 |
3 | ATDMA | 0 | 0 | 60 | 2 |
4 | ATDMA | 0 | 0 | 49 | 2 |
on 17-08-2021 12:46
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt062-b.cm |
SFID | 12148 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 12147 |
Max Traffic Rate | 38500089 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
17/08/2021 10:51:46 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 10:39:54 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 10:11:29 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 10:11:28 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 10:10:57 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 10:08:26 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:59:4 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:56:13 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:32:25 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:24:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 06:41:33 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 06:41:28 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 05:51:34 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 05:51:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 05:21:43 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 05:21:18 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 04:47:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 04:46:46 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 17-08-2021 12:59
on 17-08-2021 13:59
Been rebooted many times. What colour is the led meant to be when the hub 3 is in modem mode as mine is Red.
on 17-08-2021 14:13
on 19-08-2021 14:21
Hi @johnlucas69.
Thanks for your post 🙂
I'm sorry to hear you're having some connection issues, I appreciate this is frustrating and we apologise for any inconvenience caused.
As helpfully advised by @jbrennand, please pop the hub back into router mode to see how things perform.
If you find you're still having issues, we'll happily run some diagnostics for you.
on 19-08-2021 16:34
After tightening the cable to the router and resetting, I am only getting a few preRS errors, no post or timeouts. So I reckon the cable wasn’t tight enough. I will keep monitoring. Thanks for the help everyone.
on 22-08-2021 10:05
Hey @johnlucas69,
Thanks for the update, glad to hear there's been an improvement.
Keep us posted and let us know if you require any future assistance.
Kind regards,
