on 08-06-2022 14:44
How can I check my hub 3 connection health when in bridge mode apart from looking at the front light?
Answered! Go to Answer
on 08-06-2022 15:23
If you mean in modem mode, then go to 192.168.100.1
on 08-06-2022 14:51
If you mean the health of the hub it's a good point. When I took mine out of modem mode it stayed red and I had to get a replacement hub. Goodness knows how long modem mode red had been concealing hub knackered red but performance did dip in the lead up. You can also check that the hub stats are in spec.
on 08-06-2022 14:59
on 08-06-2022 15:23
on 08-06-2022 15:31
It looks like I can check service and reboot, if needed, from there.
