on 23-10-2020 20:04
I'm replacing a Hub 2 with a hub 3. I have a total of 3 extra Wifi networks from different routers, all effectively in bridge mode, as well as a few other obscure odds and ends with fixed IP addresses which are tedious to change.
The Hub 2's IP address was 192.168.1.1, and the Hub 3's address is 192.168.0.1. It is possible (but very tedious indeed) to change everything to match the Hub 3, so I'd prefer to make the LAN IP address of the Hub 3 into 192.168.1.1.
Is this possible? How?
Answered! Go to Answer
on 24-10-2020 10:09
@HTG10 wrote:
Oh good! So thinking laterally, as I said, I have 3 other WiFi base stations, all bridges. There's also an old Apple Airport Extreme playing at being a network drive. Is it possible to turn off the DHCP in the Hub 3, use the Wifi, and use, say, the airport extreme for DHCP?
If you put the hub into modem mode yes
on 24-10-2020 17:51
Quite true. Thanks for helping.
I put the old hub back to enable me to log in to all the old things and changed them to the 0 subnet, so I'm mostly working again. Mostly. Cheers!
