on 30-01-2022 12:18
I"ve just joined Virgin Broadband and I have what seems like an annoying bug with hub 3 (maybe others?). Perhaps others could confirm (not looking for workarounds).
To reproduce you must use a 2.4Ghz device capable of using Wireless n protocol. DO NOT USE 5ghz devices, or if you do, turn off 5Ghz for that device. I'm thinking of smart plugs, WiFi scales etc.
1) Log into hub 3.
2) Goto Wireless - Wireless signal.
3) Under 5Ghz wireless mode select 802.11ac and hit apply (This step is maybe not required but this is how I've done it).
4) Under 2.4Ghz wireless mode select 802.11n and hit apply.
After it takes a few minutes to settle any connected devices that support 802.11n will still work fine.
5) Goto Admin - Road and reboot, and reboot the hub.
This is the issue:
Wait 10 minutes or so. Your 802.11n devices (that don't run on 5ghz) cannot connect now.
Workaround:
You can put it back to 802.11 g/n mixed and hit apply and it will start working again (no need to reboot). Not ideal.
So I'm not looking for workarounds (already given it). Is this a know issue? Where can I report this to Virgin without having to go through a support desk and being told to troubleshoot? So I'm not looking for workarounds (already given it).
Thanks..
on 30-01-2022 12:53
Easiest and simplest way is to split the SSIDs into two names.
on 30-01-2022 13:37
Thanks but 802.11 is working, just not the 802.11n protocol. There is already a workaround at the bottom of my steps to reproduce.
I'm looking for others (especially Virgin engineers) to confirm what looks like a bug with the router. If so this needs to be fixed in firmware.
on 30-01-2022 14:21
Oh just to add, many workarounds have already been tried, see here:
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-3-Wifi-mode-802-11n-only-not-working/td...
I'm still just keen to stick to topic here, and find out if others can follow the steps to repro and confirm the issue, especially Virgin engineers (please fix this!).
Thanks....
on 30-01-2022 18:33
@VirAlexS wrote:Oh just to add, many workarounds have already been tried, see here:
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-3-Wifi-mode-802-11n-only-not-working/td...I'm still just keen to stick to topic here, and find out if others can follow the steps to repro and confirm the issue, especially Virgin engineers (please fix this!).
Thanks....
VM wont fix it.
Just put the hub into modem mode and be done with it.
on 30-01-2022 19:42
I want to give Virgin Media a chance to at least admit there is an issue here first. I have steps to reproduce in my first post. This is all I want to discuss.
I'm not saying you are wrong, but can we hold off from predicting how they will respond please and avoid a workaround discussion which is likely to send this thread down a rabbit hole.
Many thanks.
Virgin are you there?
on 30-01-2022 19:56
on 30-01-2022 20:02
Please let's keep to topic. Thx.
on 30-01-2022 20:06
on 30-01-2022 21:33
