Peenutz
Message 1 of 8
Hub 3 and IP cam
I've a new hub 3. I have 3 seperate IP cameras that worked fine on hub 2.0 but the hub cannot connect to the cameras. I can connect all other devices. I have split hub into 2.4 and 5, turned off firewall, but still nothing shows as connected. I can connect through ethernet. Am I doing something wrong?
  • 12.54K
  • 480
  • 1.12K
Message 2 of 8
Re: Hub 3 and IP cam
Some IP cam's don't work with the hub 3 so you may have to use modem mode and get your own router with 1Gb.
  • 32
Message 3 of 8
Hi, there.
Welcome to our Community Forum page.
How are things going on since your last post?
Let us know, so we can further assist .
Geraldine_C
Peenutz
Message 4 of 8
Thanks for that, VM 'forgot' to mention this when I upgraded.  Have ordered a router from Amazon so will set it up over the weekend 🙂
  • 29
Message 5 of 8
Hi Peenutz,
Glad to hear that your issue has been taken cared of. Let us know if
there's anything else that we can assist and we'll be happy to help 🙂
Kind Regards,
Roxie_G
Peenutz
Message 6 of 8
As my hub 3 was not recognising any of my 3 IP Camera's, I went ahead and bought a TP link Archer C7 router and put my hub into modem mode.  I still have the same problem though, the archer c7 will not recognise any of my ip camers (2.4ghz). Everything else can connect just not the 3 cameras.  I have an apeman, zmodo and yi cameras.  The ip cameras all worked fine on the superhub 2.  Any ideas?  One camera has a lan port and i connect through this, but I want wireless, and the other cameras don't have Lan socket.
  • 6.15K
  • 470
  • 1.02K
Hero
Message 7 of 8
Have you done a pin hole reset on the cameras and started from scratch. They are probably remembering the old SSID and need resetting to the new one.
Peenutz
Message 8 of 8
That makes sense but I'm afraid I'm still not having any luck.  I'll have to resign myself to buying more tp powerline adapters for the other camera. Unfortunately one of the cameras doesn't have a LAN socket so can't use that one. So it's cost me over £100 to get things working, I wouldn't have bothered upgrading if I'd have known that beforehand.
