on 29-08-2022 12:36
My hub 3 wifi keeps dropping out intermittently. It will be fine for up to an hour and then the SSID disappears for a couple of minutes. I've tried factory resetting it a few times and it still does it, but I can't see any useful logs to show it happening.
To my mind it needs replacing but based on my and other people's experience I think that will be a long and joyless process.
Can anyone suggest some way I can capture evidence or some magic form of words I can use to persuade VM of my problems?
on 29-08-2022 14:02
on 21-09-2022 14:58
Thanks for replying, and sorry for the delay getting back to you - I've been away from home for a bit.
I have checked that an ethernet connected device works fine during the wifi dropouts, and the lights on the hub stay as normal (one white and nothing else).
I have also used a wifi analyser app to watch what happens when it drops out and both the 2.4 and 5G networks are disappearing from the list of APs. It looks like the 5G comes back a bit quicker. The time taken seems to vary from a few seconds to over a minute.
Still sounds to me like the wifi parts of the hub are failing and it needs replacing.
Cheers
Tony.
on 21-09-2022 15:47
on 22-09-2022 00:03
Not in my case unfortunately. It goes off when I'm just sitting working on my laptop and nothing else is happening.
on 22-09-2022 09:37
on 25-09-2022 13:51
Hi logabex,
Thank you for reaching out to us here on the Community.
I am very sorry to hear you are experiencing issues with your WiFi service.
I would like to check some power levels from our side so I am going to pop you over a private message to grab a few more details.
This will be available via the purple envelope on the top right of this page.
Speak soon,
on 30-09-2022 08:33
Hi there logabex,
Natalie is currently out of office so I've assigned this to myself to get further updates.
I've dropped you a PM so we can discuss further.
Regards,
