  • 9.16K
  • 953
  • 1.44K
Message 11 of 22
Re: Hub 3 Wifi can use 2.4Ghz or 5Ghz but not both
Look at this thread see if any of it is useful - it seems similar
https://community.virginmedia.com/t5/Networking-and-WiFi/Password-cant-be-same-as-guest-network-but-...
  • 14.03K
  • 1.49K
  • 3.02K
Message 12 of 22
@jeffd wrote:
Did that a few times yesterday but have done it again today, no change.
Separate / different SSID don't accept password / authentication so can login to neither, unless I disable one.
Thinking I might go back to hub 2, I can't see any advantage in Hub 3. In theory I should be able to use the VM Connect app but it doesn't work on either my Swift 2X or iPad.
If you have had the intelligent WiFi update, a lot of the earlier hubs are falling foul of the password strength testing. This means the factory set passwords are seen a not secure. If once you have split the SSIDs you add a number or letter to BOTH passwords (they CAN be the same) it will work.
Click to learn more about VIP
Use Kudos to say thanks
  • 9.16K
  • 953
  • 1.44K
Message 13 of 22
You couldn't make this stuff up - priceless.  Smiley Happy
  • 38
jeffd
Message 14 of 22
yes that worked thank you but see other replies.
  • 38
jeffd
Message 15 of 22
Hi Jb,
That has helped a lot, thank you. I now have the 2 different SSIDs working. I did the guest access pw change too and rebooted.
iPad on 5 G has download of 51.9Mb
Swift 2X on 2.4 G has a pathetic 1.86 Mb 😞
  • 1.06K
  • 49
  • 99
Moderator
Moderator
Message 16 of 22
Hi jeffd,
Very glad to hear you have resolved the issues with your WiFi. These were great suggestions from our other users, thank you everyone that helped.
With regards to your speeds, there doesn't seem to be anything obvious from here causing this. Are any of your other devices connected on the 2.4G connection having issues with speeds?
Lindsey_C
  • 38
jeffd
Message 17 of 22
Hi Lindsey_C,
Only the swift 2X was connected at that time. If I connect to one of my other WAPs, I get 30+ Mb download, indicates not a problem with the Swift. It used to get those speeds on the Hub 2.
I'm leaning towards going back to the Hub 2, I can then set the LAN IP to 10.0.0.0. or 172.16.0.0 network and I'll still get firewall & network log reports emailed to me.
Cheers
Jeff
  • 1.06K
  • 49
  • 99
Moderator
Moderator
Message 18 of 22
HI jeffd.
Thanks for testing your device on other connections, we just want to be really clear if there is any interference ion your 2.4 connection.
To do this, have you got other devices you can use to connect top the 2.4Ghz connection? If you have, please can you run a speed test on these devices and see if you are getting the same issue?
Lindsey_C
  • 38
jeffd
Message 19 of 22
Hi Lindsey_C,
I'm now back on Hub 2 🙂
Just got to in 30+ yrs as an IT Pro, I haven't come across many things as dire as the Hub 3. It's even using an old Linux kernel.
Sometimes you have to accept that polishing turds is not the way forward 🙂
Cheers
Jeffd
  • 9.16K
  • 953
  • 1.44K
Message 20 of 22
How easy was it to get it reactivated (I assume you still had the hardware)?
