on 04-03-2021 11:35
I have a TP-Link Deco mesh WiFi system at home so I have disabled the WiFi on my Hub3, however recently I noticed I kept getting performance issues on my mesh network.
I logged back into my hub3 to find the WiFi had been switched back on, which I assumed must have happened since the email that came out saying Virgin had improved WiFi. I disabled the WiFi again and went about my business, only to find sometime later I was getting issues. I logged back into the Hub3 and WiFi was back on.
As a test I disabled WiFi but left the page open in my browser and periodically refreshed the page, and it seems it takes about 10 minutes before it ends up enabled again.
Does anyone have any ideas or has seen this before? I can't say when it started but I'm pretty sure this has only started up since I got the email about the router update for improved WiFi
on 16-03-2021 13:03
Hi @cd67232382,
Apologies about the late reply, and sorry to hear that you're experiencing issues with your Hub.
We've had our team look into this and they've made an update that should stop the WiFi becoming enabled again.
Please reboot your Hub and try to carry out the steps you need.
Keep us updated if this has resolved your issue, or if you need further assistance.
Thanks!
on 17-03-2021 09:27
Ok, so after rebooting the hub3, the WiFi was disabled on both 2.4 and 5 on power up, and it appears to have stayed that way for the past 2 hours.
I'd love to know what you did!
on 14-04-2021 15:32
on 14-04-2021 17:36
Hi @martinhgregory,
Welcome back to our Community forums and thanks for posting.
I am sorry to hear that that you are also having this issue.
Have you tried putting the Hub in modem mode? This way you will only be able to connect via an Ethernet cable through port one.
on 14-04-2021 19:28
I really don't want to use modem mode as I'll loose 3 of the 4 ethernet connections on the router. I need to these for the TV, cable box, etc etc.
All I want to do is disable wifi and keep it disabled.
on 14-04-2021 19:37
Thanks for getting back to me.
I am going to consult with a colleague and will update you accordingly.
on 14-04-2021 20:23
on 21-04-2021 14:52
Did this get sorted for you? I have the same issue where the router keeps enabling WIFI, which is causing me problems
on 21-04-2021 15:03
Hi @WindowAFX,
I am sorry to hear you're having a spot of bother with getting your router to disable Wi-Fi. Have you tried putting it into Modem Mode yet at all?
on 21-04-2021 15:07
I have the same need as everyone else on this thread, Ideally want to use the virgin router as a LAN router no Wi-Fi only, as I have other devices cabled into the ethernet ports.
I should be able to just disable the Wi-Fi as per design but it reenables which I don't want
