on 11-05-2023 20:20
Hi I have a Hub 3 in Router mode. Red light persistently showing. Have a Wi-Fi signal but no Ethernet, which is a problem as I rely on Ethernet heavily for work. I have gone through all the fix and troubleshooting procedures recommended by Virgin multiple times and problem persists. Router is not in direct sunlight etc. I want a new router please. Can someone from customer support please get in touch asap?
Answered! Go to Answer
on 11-05-2023 20:51
Hi there @charobham 👋 Welcome back to our forum and thanks for your post 😊
Sorry to see you are having issues with the Hub having the red light. Just to confirm, the steps you have taken, are they the below?
• Then use the power switch to turn the unit back on
If so, please let us know and we will assist further if needed.
Nathan
on 11-05-2023 20:51
Nathan
on 11-05-2023 21:34
Hi Nathan,
thanks for getting back to me so quickly. Yes I’ve taken all these steps. I’ve also done a full reset as well. Hub is out of sunlight, well ventilated etc. kind regards, Charlie
on 12-05-2023 15:26
Thanks for confirming this has been done 😊
As this is still showing the red light I'll send you a PM to confirm your details so a technician can be arranged.
Nathan
