on 16-10-2022 20:25
My Hub 3 now displays a permanent red power light, even after resetting. The does not seem to affect the 5GHz band, but the 2.4 GHz band is very intermittent. This is causing my smart devices to fail several times an hour and no new devices case be added.
Reading the forum it looks like an overheating problem and the fix is to get a new hub. I have reported to the helpline (150) and after playing 20 questions with the automated system!!! I finally got through to a person. They said they would look into it, but no reply for 4 days.
on 16-10-2022 21:21
Hub probably needs replacing, but unlikely to be the cause of your signal problems. A VM staff member will get to your post shortly or early romorrow,
on 17-10-2022 09:12
Hi Puddleduck1, thanks for posting and welcome to our community.
Sorry to hear of your red light issue on your hub. If rebooting has not resolved this, nor any of the advice here or here, helped with your connection I would love to help you resolve this. I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
