on 05-10-2021 09:30
We have had this happening for well over a fortnight now - tried all the usual fixes and automated help and it's pointless. My husband is a comms engineer and has done all the "check connections" tests he can do but it's getting really annoying now. Router has rebooted twice within an hour this morning - some days it can be 4-5 times. Husband has also had to go outside and cable tie our street cab back together even though he reported it months ago.
Can someone check this and tell us if its normal - for some reason this mornings and the last few days disconnects aren't showing up as date and time in the router seem off?
Time | Priority | Description |
27/09/2021 17:00:12 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 10:47:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 10:47:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 10:45:18 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 09:45:31 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 09:45:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 09:35:31 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 09:33:31 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 09:33:26 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 09:33:26 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:45 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/09/2021 11:29:10 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 12:25:25 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/09/2021 04:28:31 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
1 | 203000000 | -0.5 | 36 | 256 qam | 9 |
2 | 211000000 | -2 | 36 | 256 qam | 10 |
3 | 219000000 | -0.5 | 36 | 256 qam | 11 |
4 | 227000000 | -0.2 | 36 | 256 qam | 12 |
5 | 235000000 | -0.2 | 36 | 256 qam | 13 |
6 | 243000000 | -0.2 | 36 | 256 qam | 14 |
7 | 251000000 | -0.2 | 36 | 256 qam | 15 |
8 | 259000000 | -0.2 | 36 | 256 qam | 16 |
9 | 267000000 | -0.2 | 36 | 256 qam | 17 |
10 | 275000000 | -0.2 | 36 | 256 qam | 18 |
11 | 283000000 | 0.4 | 36 | 256 qam | 19 |
12 | 291000000 | 1 | 36 | 256 qam | 20 |
13 | 299000000 | 1.5 | 36 | 256 qam | 21 |
14 | 307000000 | 1.9 | 36 | 256 qam | 22 |
15 | 315000000 | 1.9 | 36 | 256 qam | 23 |
16 | 323000000 | 1.9 | 36 | 256 qam | 24 |
17 | 331000000 | 2 | 36 | 256 qam | 25 |
18 | 339000000 | 1.9 | 36 | 256 qam | 26 |
19 | 347000000 | 1.5 | 36 | 256 qam | 27 |
20 | 355000000 | 1.5 | 36 | 256 qam | 28 |
21 | 363000000 | 1.5 | 36 | 256 qam | 29 |
22 | 371000000 | 1.2 | 36 | 256 qam | 30 |
23 | 379000000 | 1.2 | 36 | 256 qam | 31 |
24 | 387000000 | 1.2 | 36 | 256 qam | 32 |
1 | Locked | 36.3 | 0 | 0 |
2 | Locked | 36.3 | 0 | 0 |
3 | Locked | 36.3 | 6 | 0 |
4 | Locked | 36.6 | 6 | 0 |
5 | Locked | 36.3 | 6 | 0 |
6 | Locked | 36.6 | 0 | 0 |
7 | Locked | 36.6 | 5 | 0 |
8 | Locked | 36.6 | 0 | 0 |
9 | Locked | 36.6 | 0 | 0 |
10 | Locked | 36.3 | 0 | 0 |
11 | Locked | 36.6 | 5 | 0 |
12 | Locked | 36.3 | 5 | 0 |
13 | Locked | 36.6 | 4 | 0 |
14 | Locked | 36.6 | 3 | 0 |
15 | Locked | 36.3 | 4 | 0 |
16 | Locked | 36.6 | 0 | 0 |
17 | Locked | 36.6 | 6 | 0 |
18 | Locked | 36.3 | 5 | 0 |
19 | Locked | 36.3 | 0 | 0 |
20 | Locked | 36.6 | 6 | 0 |
21 | Locked | 36.6 | 6 | 0 |
22 | Locked | 36.3 | 4 | 0 |
23 | Locked | 36.3 | 4 | 0 |
24 | Locked | 36.3 | 6 | 0 |
on 05-10-2021 09:39
05-10-2021 11:33 - edited 05-10-2021 11:35
Hi - didnt realise I had double posted
It's a complete hub reboot - white light etc. Hub is in Modem mode only. It has now done it for the 4th time this morning since 8am
on 05-10-2021 12:47
Had another 2 reboots since the last post - 6 times in 5 hours is ridiculous and makes it almost impossible to work reliably from home.
Also - this is what my husband had to do to our local street cab due to it being vandalised months ago and left open to the elements, despite being reported
06-10-2021 22:08 - edited 06-10-2021 22:37
No input at all on this - or is it the norm for the router to constantly reboot multiple times per day?
BQM
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/58f19b38ba91292b59b33d24cba3b521c6..."><img alt="My Broadband Ping - Virgin" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/58f19b38ba91292b59b33d24cba3..." /></a>
on 06-10-2021 22:38
No it’s not usual for the hub to reboot, what is usual is for the hub to lose connection to the VM CMTS, the equipment at the other end of your cable. The logs show that the hub has rebooted, what you need to look for is the date of 01/01/1970. You certainly need a technician’s visit to sort this out.
Call Customer Services on 0345 454 1111 or if you have a VM landline 150 or wait until a VM staff member gets to your post.
07-10-2021 22:22 - edited 07-10-2021 22:24
And 6 times again today
on 08-10-2021 08:15
Hey @ib71,
Many thanks for your recent posts and I'm really sorry for the hub issues you've been having, as well as the fact that the cabinet has not been fixed after being reported.
I've located your account and your hub is certainly running out of spec - I'll send you a private message so I can get some details from you and we can get a tech visit booked in, so please keep an eye on the purple envelope at the top of the page.
Many thanks,
on 08-10-2021 15:18
Hi @ib71
Please respond to the PM sent and we can assist further 🙂
Best,
08-10-2021 16:34 - edited 08-10-2021 16:41
Have responded now - in between router reboots 😡
Probably related but my speeds have now also dropped from over 600 to about 350 - hard wired not wireless
