Sweet16
  • 32
  • 7
Message 1 of 60
Hub 3 Disconnections
Yet another disconnection this morning 2/1/2022 at approx 0020hrs. Left disconnected until 0207hrs to allow BQM to pick up problems. No change from usual pattern. Switched off hub between 0207 and 0224 hrs to ensure monitoring correct IP. BQM showed solid red block so all correct.
Will post Logs (hopefully) below along with BQM for reference. Interestingly some of the disconnections coincide almost identically with log “Notice ATOM is restarted as part of self healing”. Maybe I’m just clutching at straws now. At my wits end. HELP please.
Time
Priority
Description
02/01/2022 09:54:26
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 00:18:49
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2022 06:48:31
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2021 11:26:37
critical
31/12/2021 10:00:35
notice
31/12/2021 10:00:14
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 08:56:9
notice
30/12/2021 03:38:39
notice
30/12/2021 03:31:38
critical
30/12/2021 02:53:35
notice
30/12/2021 02:49:36
critical
30/12/2021 02:31:3
notice
30/12/2021 02:28:38
critical
29/12/2021 23:38:20
notice
27/12/2021 15:25:57
critical
27/12/2021 09:50:30
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2021 09:33:5
notice
01/01/1970 00:01:37
critical
27/12/2021 09:19:35
notice
27/12/2021 09:11:1
Warning!
  • 6.11K
  • 513
  • 1.58K
Message 2 of 60
Re: Hub 3 Disconnections
Can you post the power levels as well for both Downstream and Upstream.
The ATOM restarting we think is due to the CPU in the Hub getting overloaded.  The restart kills the processes and starts up again on a clean slate, so to speak.
You could try a 60 second pinhole factory reset as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Sweet16
  • 32
  • 7
Message 3 of 60
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
5.5
38
256 qam
1
2
147000000
5.6
40
256 qam
2
3
155000000
5.8
40
256 qam
3
4
163000000
5.5
40
256 qam
4
5
171000000
5.6
40
256 qam
5
6
179000000
5.9
40
256 qam
6
7
187000000
6.3
40
256 qam
7
8
195000000
6.3
40
256 qam
8
9
203000000
6.3
40
256 qam
9
10
211000000
6.3
40
256 qam
10
11
219000000
6.4
40
256 qam
11
12
227000000
6.5
40
256 qam
12
13
235000000
6.5
40
256 qam
13
14
243000000
6.4
40
256 qam
14
15
251000000
6.5
40
256 qam
15
16
259000000
6.5
40
256 qam
16
17
267000000
6.6
40
256 qam
17
18
275000000
6.5
40
256 qam
18
19
283000000
6.6
40
256 qam
19
20
291000000
6.5
40
256 qam
20
21
299000000
6.8
40
256 qam
21
22
307000000
6.6
40
256 qam
22
23
315000000
7
40
256 qam
23
24
323000000
6.9
40
256 qam
24
  • 6.11K
  • 513
  • 1.58K
Message 4 of 60
Can you post the Pre and PostRS errors from the Downstream tab as well.  Also the Upstream, thanks !
Sweet16
  • 32
  • 7
Message 5 of 60
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300288
43.8
5120
64 qam
1
2
53700074
43.8
5120
64 qam
2
3
39400175
43.3
5120
64 qam
4
4
46200064
43.5
5120
32 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Sweet16
  • 32
  • 7
Message 6 of 60
channels
11390000005.538256 qam1
21470000005.640256 qam2
31550000005.840256 qam3
41630000005.540256 qam4
51710000005.840256 qam5
61790000005.940256 qam6
71870000006.340256 qam7
81950000006.340256 qam8
92030000006.340256 qam9
102110000006.340256 qam10
112190000006.540256 qam11
122270000006.540256 qam12
132350000006.540256 qam13
142430000006.540256 qam14
152510000006.540256 qam15
162590000006.540256 qam16
172670000006.640256 qam17
182750000006.540256 qam18
192830000006.640256 qam19
202910000006.640256 qam20
212990000006.840256 qam21
223070000006.640256 qam22
23315000000740256 qam23
243230000006.940256 qam24
1Locked38.690
2Locked40.350
3Locked40.960
4Locked40.360
5Locked40.340
6Locked40.3140
7Locked40.3220
8Locked40.3180
9Locked40.9190
10Locked40.360
11Locked40.350
12Locked40.370
13Locked40.950
14Locked40.350
15Locked40.960
16Locked40.350
17Locked40.360
18Locked40.350
19Locked40.360
20Locked40.3110
21Locked40.370
22Locked40.340
23Locked40.360
24Locked40.960
  • 6.11K
  • 513
  • 1.58K
Message 7 of 60
One of your Upstream is at 32QAM, and they all should be 64.  I suspect this may be the problem.?  All the rest of the stats look fine.
A VM technician will be required to fix this. If you wait here a day or two, a VM Mod will pick this up.
In the meantime you could try the full reset ?  Just bear in mind this is a complete reset, so any custom changes you may have made on the Hub will be lost.
Sweet16
  • 32
  • 7
Message 8 of 60
Thank you for your help. Glad someone actually believes me and that a problem is evident. How will I know that this problem has been actioned?
Sweet16
  • 32
  • 7
Message 9 of 60
Reference back to my earlier post a few days ago on same issue. All four upstream channels were set at 64 although one of these now appears to be at 32 on latest post?. Why would this change. In addition, when I initiated the BQM the other day it ran for 12 hours and then suddenly stopped whilst recording solid red bar ( packet loss). The only way I could get the BQM to monitor again was by disabling the firewall?. Not sure what is going on with this connection. Could hub be faulty? I am loath to purchase an independent router and switch the VM Hub 3 to modem if the same issue is likely to be experienced.
gary_dexter
  • 32.63K
  • 2.02K
  • 4.47K
Message 10 of 60
You need to wait for a forum mod to reply with the next steps
