on 08-01-2024 00:29
Hi there,
Connection went off around 7pm today.Hub has been showing a constant red light ever since.
I’ve done all the tests recommended in forum searches:
*Unplugged Ethernet cables in all instances.
*Checked and secured all cable points, including at splitter.
Turned off at wall to reset, 5 times.
30 second reset button reset, 3 times.
Used virginmedia online utility to reset hub (20 minute)
I’m getting no joy, can anyone offer any help or advice please?
on 08-01-2024 09:07
Hey Ivanskavinsky, thank you for reaching out and I am sorry to hear this thank you for confirming these steps for me.
I am going to send you a PM so we can look into this, please do look out for it.
You can also try these steps in the meanwhile;
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
Matt - Forum Team
New around here?
