  • 14
trenko
Message 1 of 7
Hub 3. Can't change wireless channel
Received hub today. Setting up I find I can't change wireless channel on 2.4 and 5ghz from manual to auto.(router page) The buttons are just not clickable. Also when setting up I renamed the ssid for 2.4 and 5ghz to different names. Just done a router reset exactly as it said..... I expected everything back to default but nothing happened. I still have the altered settings I made an hour ago, tried again 20 seconds reset press, router off for 60 seconds and same again...... any ideas ?
  • 8.61K
  • 884
  • 1.34K
Message 2 of 7
Re: Hub 3. Can't change wireless channel
Probably too obvious - but you did click the "save changes" button before logging out ?
  • 14
trenko
Message 3 of 7
Yes, saved clicked each time.No big deal that bit it is mainly why it won't let me go from manual to auto wireless channel. I would have thought anyway that auto would be default
  • 13.9K
  • 1.47K
  • 2.97K
Message 4 of 7
Go to the bottom of the screen & disable "Smart WiFi". Then you will be able to change your settings.
Cable customer since 1993. Services: FH TV, Sky Sports/Cinema (2xV6), Talk Anytime Phone, 350M BB, Virgin PAYG Mobile
  • 14
trenko
Message 5 of 7
Got it...... i never new I had to click "Disable Channel Optimization" at the bottom of the page. Now I can alter it.
  • 13.9K
  • 1.47K
  • 2.97K
Message 6 of 7
Channel Optimisation is strictly speaking the automatic setting. With it disabled the Hub will not do a periodic search for the best channel to use.
The individual Auto settings only operate after a reboot.
  • 16
Yamkin
Message 7 of 7
You have saved me from doing a factory reset!! Thank you so much for your easy fix. Just had a new 3.0 Hub connected as the old 2.0 Hub stopped the household from accessing BBC iPlayer!!
