Aga1976
Just joined
Hub 3.0 settings
Hi, I wanted to change the Hub 3.0's settings and when I go to type in my settings password it says it is incorrect. Could someone tell me why this is happening as I have typed in the password many times and it still isn't working.
  • 3.65K
  • 201
  • 608
chenks
Community elder
Re: Hub 3.0 settings
are you sure you are using the router admin password and not the wifi password?
the router admin password should be on a sticker on the hub3.
