  • 6
steveflats
Message 1 of 9
Hub 3.0 settings password not working
I have the problem which some other people are  having where the settings password does not work any more.  I have done the reset several times, i.e. putting a pin in the hole and holding down for 60 seconds. Then turning the router off for a minute and then restarting but none of this works.
I need to get into settings and cannot. Please help
Steve
  • 6.23K
  • 482
  • 1.03K
Hero
Message 2 of 9
Re: Hub 3.0 settings password not working
Do the pin hole reset, BUT do not turn off the hub. Then try the numeric password.
  • 2.82K
  • 142
  • 419
jpeg1
Trouble shooter
Message 3 of 9
Are you certain you are using the Settings password and not the WiFi password?
  • 6
steveflats
Message 4 of 9
I tried that and it still does not work but thanks.
  • 6
steveflats
Message 5 of 9
I am using using the correct password and not using the WiFi password ...
  • 6
steveflats
Message 6 of 9
bump ...
  • 6
steveflats
Message 7 of 9
Just phoned virgin media and the representative went through the reset with me and it still did not work.  Was told it is an issue with the Hub 3  and they are sending out a new Hub.  Problem resolved. 🙂
mnuessli
Message 8 of 9
I have the same problem. I wanted to change the routers password in the setting panel but I can't login even though I've never changed this password. I already tried to reset it several times but it doesn't work. I need to get into settings because I have the impression that my Wifi got hacked.
M
  • 725
  • 32
  • 55
Message 9 of 9
Hello Mnuessli, thank you for your post and welcome to our community.
Have you already performed a pinhole reset on the router to bring everything back to factory settings?
Let us know so we can advise further if needed.
Thank you, Emily.
