on 12-04-2018 10:45
Hub 3.0 settings password (which is printed on the bottom of the router) isn't working. Does Virgin reset this with a different default password and if so how do I get it?
on 11-11-2020 10:28
on 19-11-2020 17:18
Hi Cesa,
Very sorry for the delay in getting back in touch, we have been busier than usual.
I am sorry you've been having some issues with the hub password, this isn't good.
Due to the delay can I ask if this has been sorted for you now, if not please let us know and we can help further if needed.
on 21-11-2020 15:10
on 16-07-2021 09:32
This workaround did work for me too, but I can understand the reluctance to unnecessarily have to do this.
Yes, the settings password was reset, allowing me to change my router password back to what it should be, but it then took me about 1.5 hours to update every linked device in my home.
The Sonos products were the hardest. If you change the router settings, you then have to wire the product to the router with an ethernet cable and the whole process takes forever.
Once I can live with, if it happens again it will really start to grate.
