on 12-04-2018 10:45
Hub 3.0 settings password (which is printed on the bottom of the router) isn't working. Does Virgin reset this with a different default password and if so how do I get it?
on 05-03-2020 18:23
Hi Neal-UK
Sorry you are experiencing the same issue
When you say resetting do you mean a mains reset or a factory reset
Pinhole at the back of the hub?
Gareth_L
on 06-03-2020 21:58
on 06-03-2020 22:00
Persevere with the factory resets, it took 4 attempts for me earlier this year,
With the Hub Powered on use a paperclip or similar and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
on 08-03-2020 16:44
on 05-05-2020 15:38
on 12-07-2020 05:57
i also have this issue anyone have a fix ?
on 12-07-2020 08:11
Hi Trav97,
Thanks for posting and welcome to our community 🙂
I'm sorry to hear you're having some issues with the hub password.
Can you confirm if you've done a pin hole reset of the hub?
Alex_Rm
on 13-07-2020 10:17
hi, yes i've reset using the pin hole but still says wrong password
on 13-07-2020 10:42
That is most odd @Trav97 - this is the only way to reset to factory settings.
Please confirm that you held it in for minimum 60 seconds? (Whilst the website advises 10 seconds, we have found that 60 seconds has more success.
I can see from looking at your account that it has been around 27 hours since your hub was rebooted. Pop back to let us know how you get on.
Cheers
Katie - Forum Team
on 19-07-2020 12:02
Hi, it worked! Thank you, I never held for longer than 10 seconds but 60 seconds seemed to do the trick 🙂 thank you!
