on 16-02-2022 13:55
My VM hub 3.0 is regularly crashing and requiring a power cycle to recover. This has been happening for a few months now, but now happens on average 1-2 times per day.
I have a mixture of Ethernet and WiFi connections to my hub, including a couple of additional WiFi hotspots to provide coverage in far corners of my house which are connected over Ethernet.
The symptoms are that internet connectivity just stops working for all devices, both wired and WiFi, but it always recovers when I power cycle the hub, suggesting that it's the hub that has crashed. This is backed up by the fact that I can't ping the hub (on 192.168.0.1) when it's down.
I have tried one call to VM, but was put through to someone who could only read from a pre-prepared script which was no help at all. (I am technically competent having spent many years working in IP/telco).
Can anyone suggest troubleshooting that I could do, or how to get through to someone at VM who can help resolve the problem and not just follow a script? I suspect I need a new hub, but how to convince VM of that?
on 16-02-2022 15:44
on 21-02-2022 09:21
Good Morning @Fenelon70, thanks for your post and a very warm welcome to our Community Forums!
Are you possibly able to address the response from @jbrennand and provide us with an update?
Kindest regards,
David_Bn
on 02-03-2022 14:56
Thanks for the suggestions. Thankfully by broadband has stabilised and I have not hit the issue for a couple of weeks now. I will monitor and see if it recurs.
