Hayden98
Hub 3.0 lights
Hi my hub 3.0 has the normal white light on but the green WiFi light is flashing my internet is all working I’ve tried a re start but it’s still doing it what can I try next
  • 5.3K
  • 105
Moderator (Retired) Ty_S
Moderator (Retired)
Re: Hub 3.0 lights
Hi Hayden98
I’m really sorry to hear of the issues you have been experiencing.
How are things looking with your broadband connection now?
Kind regards
Hayden98
Re: Hub 3.0 lights
Still the same it all works ok it can be a bit slow sometimes but the green WIFI light is still flashing. The bottom white light is on solid and the top WIFI light is flashing green
  • 5.3K
  • 105
Moderator (Retired)
Re: Hub 3.0 lights
Hi Hayden98
Thanks for getting back to me. How are your speed tests looking over ethernet? You could try changing the WiFi channel. I've included a link with some helpful info here.
Speak soon
