  • 12
Patricia1066
Message 1 of 5
Hub 3.0 dropping out - Router mode
I have had an engineer visit and had the coax cable replaced from the box on the interior wall to the Hub 3.0 yesterday. The engineer suggested that we replace any old ethernet cables, and I have replaced one long cable that had got twisted. There are no attenuators as the phone line has a separate entrance to the house. No TV package.
This morning the Network logs were full of critical errors, but I got online with Hub 3.0 in router mode. I did the 200 ping test, and during the test there was a general failure that resolved by the Hub reconnecting and only 5% loss. I want to run the Hub 3 in modem mode, but it seems to "work" and reconnect better in router mode. Or is my observation irrelevant?
Cable Modem Status
Item
Status
Comments
266750000
Locked
Ranged Upstream Channel (Hz)
35800019
Locked
Provisioning State
Online
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
54k;fg87dsfd;kfoA,.i
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
266750000
-2.2
38
256 qam
17
2
194750000
-1
38
256 qam
8
3
202750000
-1.2
38
256 qam
9
4
210750000
-1.5
38
256 qam
10
5
218750000
-1.5
38
256 qam
11
6
226750000
-1.7
38
256 qam
12
7
234750000
-1.9
38
256 qam
13
8
242750000
-2
38
256 qam
14
9
250750000
-2
38
256 qam
15
10
258750000
-2
40
256 qam
16
11
274750000
-2.7
38
256 qam
18
12
282750000
-2.7
38
256 qam
19
13
290750000
-2.7
38
256 qam
20
14
298750000
-2.7
38
256 qam
21
15
306750000
-2.9
38
256 qam
22
16
314750000
-3
38
256 qam
23
17
322750000
-3.5
38
256 qam
24
18
402750000
-3.9
38
256 qam
25
19
410750000
-3.7
38
256 qam
26
20
418750000
-3.7
40
256 qam
27
21
426750000
-3.5
38
256 qam
28
22
434750000
-3.5
38
256 qam
29
23
442750000
-3.7
38
256 qam
30
24
450750000
-3.5
38
256 qam
31
  • 12
Patricia1066
Message 2 of 5
Re: Hub 3.0 dropping out - Router mode
Further info
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
6179
179
2
Locked
38.9
4384
0
3
Locked
38.9
4528
4
4
Locked
38.9
4695
6
5
Locked
38.9
5097
13
6
Locked
38.9
5461
16
7
Locked
38.9
5688
50
8
Locked
38.9
5819
129
9
Locked
38.9
6117
117
10
Locked
40.3
6144
169
11
Locked
38.9
6114
284
12
Locked
38.9
6189
257
13
Locked
38.9
6114
386
14
Locked
38.9
6107
419
15
Locked
38.9
6065
505
16
Locked
38.9
6004
587
17
Locked
38.6
5965
616
18
Locked
38.9
5927
678
19
Locked
38.9
5945
713
20
Locked
40.3
6097
551
21
Locked
38.9
6018
624
22
Locked
38.9
6029
638
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
35800019
4.475
5120
64 qam
2
2
53700026
4.325
5120
64 qam
4
3
27400017
4.475
5120
64 qam
3
4
45800019
4.475
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
SFID
6697
Max Traffic Rate
57500000
Max Traffic Burst
10000
Min Traffic Rate
0
  • 12
Patricia1066
Message 3 of 5
Another update
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID
6697
Max Traffic Rate
57500000
Max Traffic Burst
10000
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
2601
Max Traffic Rate
5250045
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Refresh data
Time
Priority
Description
10/09/2019 07:49:55
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2019 07:49:56
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2019 07:51:3
Warning!
10/09/2019 07:51:4
Warning!
10/09/2019 07:51:11
Warning!
10/09/2019 07:51:12
Warning!
10/09/2019 07:51:31
Warning!
10/09/2019 07:51:32
Warning!
01/01/1970 00:01:38
critical
10/09/2019 09:39:38
Warning!
10/09/2019 09:39:43
Warning!
10/09/2019 09:39:43
Warning!
10/09/2019 09:39:43
Warning!
10/09/2019 09:39:44
Warning!
10/09/2019 09:39:46
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2019 09:39:46
Warning!
10/09/2019 09:39:47
critical
10/09/2019 09:39:49
Warning!
10/09/2019 09:40:25
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2019 05:49:28
critical
  • 4.23K
  • 281
  • 710
Roger_Gooner
Community elder
Message 4 of 5
Your hub is losing network lock but failing to properly establish it again. Check that all cable connections are tight and call 08005610061 to find out if there is a fault. If you find no problem then call VM to get a technician sent round.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 12
Patricia1066
Message 5 of 5
The third engineer in a week called today. He took out a noise meter and saw high levels of noise on the line and isolated it to the cabinet . He saw an obvious fault as the wiring in the box is very old and the connection was rusty.
The connector is now replaced and if I get further drop outs they will replace the cable.
