MAC_MATHS
Message 1 of 5
Hub 3.0 dhcp_setting&mid=DHCP Hangs, Unresponsive
The  Router firmware page  [dhcp_setting&mid=DHCP hangs], like other posts, this is not a user problem, since virgin promoted there Intelligent Wifi, i.e. all it does is change channels by the number of devices on various channels, [turn off - if you have numerous devices, waste of time], when your DHCP Setting Page is unresponsive there's nothing you can do until Virgin Media FIX this problem.  The problem will be either whether Virgin Media regard this problem as important, or , they are ignoring users concerns, thinking it's a user issue, or fixing it has implications on there Intelligent Wifi - in which isn't intelligent by the way.  So I guess I will make my Google Wifi the router in which I have Bridged, should have done this at the set off.  I really need to allocate fixed IP Addresses though as I have a lot of Google Mini's and Homes.  These frustrations are common with ISP's.  Oh Well that's Life I guess.
  • 17.68K
  • 968
  • 7.3K
Message 2 of 5
Re: Hub 3.0 dhcp_setting&mid=DHCP Hangs, Unresponsive
@Kev_B
Can I echo this concern.  It's just took the DHCP page over 3 minutes to update here while it gets the list of current DHCP devices.  During that update I repeatedly got warnings from chrome that a script on the page was making the page  unresponsive.  After pressing wait several times the page FINALLY came up with the full list of devices including the one DHCP reservation I had.
This is frustrating for users.  Can someone please speak to the Firmware team about this?
Tim
Click to learn more about VIP
Use Kudos to say thanks
  • 6.7K
  • 217
  • 1.15K
Community Lead
Community Lead
Message 3 of 5
Thank you both for bringing this up - I've passed the feedback along to the firmware team.
Sorry that it's causing you some pain at the moment.
Kev
MAC_MATHS
Message 4 of 5
This issue still remains. In fact it's got so bad, you can't block MAC Addresses or Assign IP's to MAC Addresses, because your session response terminates.
MAC_MATHS
Message 5 of 5
Re: Hub 3.0 dhcp_setting&mid=DHCP Hangs, Unresponsive "STILL OUTSTANDING"
 This issues is still outstanding
First Reported 15.04.2019
That's 129 Days.  What I did, put Hub 3.0 in modem mode, and purchased Google Wifi,, then assigned Static IP's.  The Hub 3.0 is not fit for purpose.
